Cold Air Intake from Ebay. Will it fit?
Old Feb 4, 2012 | 09:11 PM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
http://www.ebay.com/itm/330548988551...ht_4076wt_1396
Well i've seen this and I am wondering.
Why wont it fit on a Camaro?
I own a 87 IROC 5.7 and I've been thinking about getting an intake like this or building my own. This seems pretty cheap ( I might just use it as reference to make my own) And of course I will shroud it off to protect from heat.
Old Feb 4, 2012 | 09:31 PM
Engine: HSR L98
Axle/Gears: stock
Re: Cold Air Intake from Ebay. Will it fit?
ohh....is it because of the battery?
Old Feb 4, 2012 | 10:14 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
that, And our camaro might not have the area where this item
sucks air from, given the front bumper cover areas are very different per car.
Old Feb 5, 2012 | 12:17 AM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
Our TPI's are already cold air intake, just a little restricted...
Old Feb 5, 2012 | 12:28 AM
blackdoutgta5.7's Avatar
Car: 1989 gta
Engine: 5.7 ltr
Axle/Gears: 9 bolt 3.27 limited slip
you are correct the stock placement of the air intake is really pretty good for getting cold air and yes this kit will work im using a red one now and it works great on my firebird, I noticed a difference in throttle response and low end acceleration and a throaty sound too....
mike,
Old Feb 5, 2012 | 12:29 AM
Car: 1989 gta
Engine: 5.7 ltr
I think I paid 70 bucks for mine for that price I'll let them make it for me.
Old Feb 5, 2012 | 09:48 AM
Engine: HSR L98
Axle/Gears: stock
Yea I know they are good but mine is kinda cracked apart and I just wanted to give something like this a try.
Going to the junkyard this week where I know there are a few IROCs and hopefully will be able to pick one up.
So I will mostly likely buy this and it will be next weekends project!
Old Feb 5, 2012 | 10:59 PM
darrlee's Avatar
Car: 85 IROC
Take some pics if you put an aftermarket cold air on it... I'd like to see how you work around the battery.
Old Feb 5, 2012 | 11:18 PM
Engine: HSR L98
Axle/Gears: stock
I would just switch the battery to the driver side
Old Feb 8, 2012 | 09:50 PM
Engine: HSR L98
Axle/Gears: stock
Just realized I have no idea how to relocate the battery to the drivers side....
Old Feb 8, 2012 | 10:05 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Easiest way is to rob everything for the battery & air intake from a JY Firebird.
Old Feb 13, 2012 | 10:38 PM
Looney's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 10 bolt/3.27
Does anyone know where the mass airflow sensor would go?does it come with one or do you put yours in it...? Thinking of getting one of these too but I've got an 87
Old Feb 14, 2012 | 12:16 AM
Car: GTA
Look at the ebay pic again. It has the MAF & Firebird location filter. The pic has your answer.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
