Stuck spark plug
Old Feb 8, 2012 | 11:25 AM
AO91's Avatar
Stuck spark plug
I have a 1986 Trans am 305 TPI, I was in the process of giving it a full tune up (just got the car no idea how the previous owner trated it) so I started the spark plugs managed to get two switched with fairly little difficulty but now the third plug back on the drivers side is STUCK, and I mean stuck to the point where it will not budge at all. I ended up breaking the stalk off and am getting irriated with the damn thing. Any tips or advice to try would be helpful. Thanks in advance.
Old Feb 8, 2012 | 11:32 AM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
Re: Stuck spark plug
PB blaster or Kroil...and some heat, propane or mapp gas and heat that fellow up.
Old Feb 8, 2012 | 11:51 AM
Conradzz's Avatar
Not quite sure how its stuck... Are you using a spark plug socket? I picked up those flexible ones from harbor freight, and they work fine.
Old Feb 8, 2012 | 12:04 PM
AO91's Avatar
Is PB Blaster that effective? The only heat I really have access to is a lighter.
Old Feb 8, 2012 | 03:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You will need a Propane torch at the very least.
Old Feb 8, 2012 | 04:00 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Home depot for like $20. And yeah pb blaster works good. Remember though if you blast it full of oil and then use the torch you might see a little more smoke than you expected. Best to lick the plug with the tip of flame on low and burn oil off first. Keep a wet rag handy to slap over fire if it gets a little frightening.
Old Feb 8, 2012 | 04:29 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
pb blaster is that good
Old Feb 8, 2012 | 08:24 PM
Engine: LB9 305
best to heat first , the spray with the blaster, it will smoke but the heat will pull the penetrant into the threads just like when you solder cooper pipe.
Old Feb 9, 2012 | 02:39 PM
AO91's Avatar
Thanks for the tips, I picked up some pb blaster and have been soaking the plugs. I have my brother coming down in a couple of days to give me a hand with finishing the job up. If all else fails bringing it to a shop and they can deal with it.
Old Feb 9, 2012 | 02:42 PM
ninetyone's Avatar
Axle/Gears: 3:42
why dont u just put a long pipe around your socket wrench for more torque/leverage?
Old Feb 13, 2012 | 01:15 AM
AO91's Avatar
PB blaster and a breaker bar and I was able to get the plugs changed, thanks for the tips and advice from everyone
Old Feb 13, 2012 | 01:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
put a lil dab of anti-seize on the threads of your new plugs.
Old Feb 13, 2012 | 01:22 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Good advice.
Old Feb 13, 2012 | 01:45 AM
AO91's Avatar
Trust me I did lol not going through all that trouble again.
Old Feb 13, 2012 | 04:53 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
if not careful he might twist the plug into ,leaving the threaded part still in the head.ask me how i know this!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
Jlanz55
Sep 6, 2015 03:05 PM
