Help with 1989 iroc 305 tpi ruff idle and dies
Old Feb 21, 2012 | 03:18 PM
BayAreacustoms's Avatar
HI To everyone,just got an 1989 Iroc conv.It runs terrible the idle goes up and
down for about 5 mins then dies.Car won't start again.Have to let it sit,starts up and does the same thing.The previous owner replaced the following Egr,iac,
ignition module,fuel pump,maf,tps,all relays,coil,fuel cap,thermostat,and o2 sensor.I was going to get a new ecm,injectors and distributor.Just don't want
to keep throwing parts at it.I have read allot of the posts on here and they are very help full.Tps is set right and i played with it to see if any thing helps no luck.I think its the ecm but not sure.Thanks please help
Old Feb 21, 2012 | 05:48 PM
ex-x-fire's Avatar
Re: Help with 1989 iroc 305 tpi ruff idle and dies
Get a fuel pressure tester, it should be 36-42psi while running, & hold psi when engine is off.
Disable the egr valve, it might be getting vacuum at idle, which it shouldn't.
Old Feb 21, 2012 | 06:23 PM
I just check ed fuel pressure and it's 42.Disconnected egr nothing changed.
Did get code 42"the est signal did not change when the ecm applied bypass voltage to the ignition module.
The previous owner said he replaced the module.I am leaning towards the
ecm is bad.Any thoughts
Old Feb 21, 2012 | 06:33 PM
ex-x-fire's Avatar
Check the ecm grounds carefully, usually at the backof the heads or near the t stat. or do a continuty test at the ecm connector to ground.
Old Feb 21, 2012 | 06:39 PM
How do i do continuity test at the ecm?Thanks for your help.i am pulling my hair out
Old Feb 21, 2012 | 06:45 PM
ex-x-fire's Avatar
You can get a volt meter, set it to ohms, put one end on a good ground (battery is best) & the other probe the ecm connector. You'll need a good repair manual the shows the ecm connector view & what each pin does, while your there check the proper voltages too.
Attached Thumbnails Help with 1989 iroc 305 tpi ruff idle and dies-digital_multimeter_md.jpg
Old Feb 21, 2012 | 06:47 PM
I'll try that.When the car is running i am getting water coming out the tail pipes.
Is this common?
Old Feb 21, 2012 | 06:53 PM
ex-x-fire's Avatar
Alittle water is common, condensation. Is it coolant?
Old Feb 21, 2012 | 06:56 PM
I don't think its coolant.I have a Chilton repair manual and it doesn't have much info
on the ecm or what each wire does.Is there a source on the internet that i could get info
on?Again thanks
Old Feb 21, 2012 | 07:08 PM
The car will run fine when first started up,then in about 5 mins or so the idle jumps around and eventually dies.It's kind of weird and it smells like its running rich.When it
dies it almost acts like its flooded,becaues it wouldn't start back until it sites awhile
Old Feb 22, 2012 | 05:20 PM
Any one else have suggestions,it driving me crazy.Thanks
Old Feb 25, 2012 | 05:10 PM
Well i replaced the ecm and car runs better doesn't seem to want to die.Still
the idle isn't right it searches up and down about 200 rpm.Anyone have
any ides.And car smells very rich out the tailpipes.Thanks
Old Feb 25, 2012 | 05:40 PM
ex-x-fire's Avatar
Clean the maf sensor.
Do a resistence check on the coolant temp sensor, google "GM cts resistence ohms" for the values/temps. You'll need that volt/ohm meter though.
Old Feb 25, 2012 | 05:43 PM
Thank you
Old Feb 27, 2012 | 03:54 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
check for a cracked magnet on distributor under rotor. Could keep contact until it warms up and then it expands and separates causing open. Saw this on a 94 chevy truck. Don't know if it applies here.
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
