305 to 350 TPI swap, some questions about heads and cam
Old Feb 28, 2012 | 03:47 PM
Blue1990camaro's Avatar
ok so i have an 85 z28 305 TPI that just blew up, blew the crank outa it and sumhow took part of the cam with it slinging it outa the side of the block
ANYWAY top end still seems good, ill know more when i pull the heads off
so im building a mild 350 but wana use the TPI setup from the 305 on it
WILL these heads and cam work with the tpi on the 350?
i have a set of world product torquer steel heads cast S/R I-052
and a wolverine cam 280/290 duration and 480/490 lift
i know ill prob need a different ecm and a custom chip but at the moment im worried if the cam will be to much for TPI or the heads wont bolt up to the tpi LIM
Old Feb 28, 2012 | 04:07 PM
Re: 305 to 350 TPI swap, some questions about heads and cam
also the 350 im using is a 2 bolt main outa a 1992 G20 van, its only a temp botom end while i look for a 0010 block 4 bolt main, i just need her running so the 2 bolt should be fine, im only guestimating under 350hp and 400trq
will the G20 oil pan work in the camaro?
Old Feb 28, 2012 | 04:19 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I'm doing the same thing. 1992 G20 350 in my 'Bird.
Old Feb 29, 2012 | 11:28 AM
did teh G20 oil pan work in the bird? or will it hit the frame or something?
also im gona b running big heads and a very big cam and port work, do u think the 2 bolt main will b strong enough or should i buy a new 4 bolt?
Old Feb 29, 2012 | 06:19 PM
Transmission: WC T5
2 Bolts can handle power just fine.
Have not dropped the G20 350 in yet but I think the pan fits.
Old Mar 1, 2012 | 04:16 PM
ok cool, we are estimating roughly 370hp at the crank with this motor, im starting a project thread now
Old Mar 1, 2012 | 06:38 PM
Transmission: WC T5
When you are making over 500+ horsepower you can start worrying. Link to project thread?
Old Mar 18, 2012 | 12:30 PM
heres the project thread
https://www.thirdgen.org/forums/memb...ct-85-z28.html
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
