whats my weight?! i cant figure it out!
Old Feb 28, 2012 | 10:58 PM
nowerelsetoroam's Avatar
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I have and 85 camaro berlinetta and I've searched all over and I can't.find how much it weights! I found one site that said.its about 3100 lbs but is that correct?
Anyone know the correct weight? And help would be apreciated! I'm just trying to figure out how much it would end up weighing with the swap.I'm doing in.it.
Old Feb 28, 2012 | 11:07 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: whats my weight?! i cant figure it out!
There is no way to specifically know YOUR cars weight without weighing it. Too many options to add/subtract plus the age means there is no telling what it still stock or changed.
Old Feb 28, 2012 | 11:13 PM
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Darn lol I was hoping there was like a list lol I'm trying to make it as light as possible
Old Feb 29, 2012 | 12:22 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Go to a scales and weigh the thing. Recycling centers and land-fills have scales, also grain elevators and some salvage yards.
Old Feb 29, 2012 | 12:43 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep this is akin to 'how much lift can I run', 'what dimensions for my sub box' etc etc. Gonna have to measure your specific vehicle.
Old Mar 1, 2012 | 10:18 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
This. 3100 lbs should be close for a v6 car but it will depend a lot on your transmission, options, wheels, mods, spoiler/louvers, junk in your car, amount of gas and fluids, etc. Call around, any landfill should have a scale and as long as you don't go when they're busy they shouldn't mind.
Old Mar 1, 2012 | 11:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
3100-3600 is the ballpark numbers for third gens. As mentioned above, too many options available for the cars which can really change the weight. The only way to know the true weight is to put it on a scale.
Old Mar 2, 2012 | 08:53 AM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
Go to any weigh station along any highway and, check it out. They usually will weigh you up without any problems.
Old Mar 3, 2012 | 10:08 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I put my 84 Berlinetta on a truck scale a few years back - 3600 pounds. The car was not stock, (355ci, T-Tops, No Smog/AC, Glass hood, EVERY option + several extras ! ) but most Berlinettas are fully loaded with options so that should be 'close' to your wieght.
P.S. My 95 Z28 ( mostly stock at the time ) was 3700.
92firebirdguy
Sep 1, 2016 07:53 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Fronzizzle
Sep 8, 2015 12:10 PM
roysatikas
Sep 7, 2015 08:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
