knock ping sensor
Old Mar 7, 2012 | 04:22 PM
bigcountry1979's Avatar
Car: 90 iroc z
Transmission: 4 speed with od
Axle/Gears: 323 ratio
knock ping sensor
Knock ping sensor goes off n on"a lot no engine lite! How is it bad r can I jst remove it? R wat?
Old Mar 7, 2012 | 04:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: knock ping sensor
Originally Posted by bigcountry1979
Knock ping sensor goes off n on"a lot ?
How do you know?
r can I jst ?
R wat?
Speaking English helps ;this is not a TXT site
Old Mar 7, 2012 | 04:56 PM
Car: 90 iroc z
Well obviously its knock sensor"very loud cling pinging sound!it comes n goes"always under heavy throttle,I know I need a idle control vavle cause of error code"but would idle control make sensor knock?jw
Old Mar 7, 2012 | 07:07 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Obviously not
Knock sensor doesn't make any noise ;
is just a device to tells the computer that the engine is knocking so it can adjust the timing
What you have is " engine knock"; the engine is pre-igniting under load due to bad timing / bad fuel
could be many things
There is no error code for IAC faults
Old Mar 8, 2012 | 07:20 AM
Car: 90 iroc z
Any ideas were to start? Guess its my lifters pinging?like I said smetimes it does it n smetimes it dnt!seems like it doesn't do it when its cold tho!
Old Mar 8, 2012 | 06:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Lifters can't ping.
You have detonation problems in the cylinders ( worst when engine hot)
Timing is out , cr*p gas ,engine temp too hot ; could be one or all those or other problems
Start with the basics by setting timing
Old Mar 8, 2012 | 06:52 PM
Car: 90 iroc z
' Thks ima try a new low temp thermo stat also"after timing is check again"
Old Mar 8, 2012 | 07:20 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
lower your timing if it is pinging
Old Mar 8, 2012 | 07:21 PM
ninetyone's Avatar
Axle/Gears: 3:42
low temp thermostat without changing the fans on/off temperature in the chip wont do much
Old Mar 8, 2012 | 07:34 PM
Car: 90 iroc z
Even with a 160 thermo? And how would I change the fans temp turnon time?
Old Mar 8, 2012 | 08:19 PM
ninetyone's Avatar
Axle/Gears: 3:42
you would have to burn or get another chip burned. you could always buy the hypertech fan switch tho.http://thmotorsports.com/i-296854.as...ingSeanVehSpec
it installs between #6&8 cylinder (passenger side)
Old Mar 8, 2012 | 08:20 PM
ninetyone's Avatar
Axle/Gears: 3:42
this is not going to fix your pinging issue. you need to lower your timing
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
