Extremely loud and embarrasing rattle / starter?
Old Mar 25, 2012 | 09:50 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
As I'm driving around, or even just letting it idle, a rattling sound sometimes starts. I think it's the starter trying to engage the flywheel randomly. Is that possible? Could the starter gear be lossely sliding around hitting the flywheel making the sound? I don't know if I should replace the starter. I'll try to get a sound clip of the rattle if it helps.
Old Mar 25, 2012 | 11:34 PM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Re: Extremely loud and embarrasing rattle / starter?
I just had an issue that sounds exactly like yours. Ended up being my flex plate.. I took my trans off and did all this in a hole I dug underneath my car lmfaoo. So long long story short.. My flexplate was cracked.. Just replaced it noise gone :P
Old Mar 26, 2012 | 05:02 AM
chevydrvr's Avatar
Is a cracked flexplate an obvious thing to see? I have to drop the trans to fix that don't I?
Old Mar 26, 2012 | 05:16 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Look pretty good- sometimes the weld that holds the ring gear will fail,
also look around the flywheel bolts.
See how easy the starter bendix pulls out from the solenoid.
Old Mar 26, 2012 | 05:19 AM
chevydrvr's Avatar
Ill have to check that sometime soon. And find a way to fix it, The sound is obnoxious!
Old Mar 26, 2012 | 01:28 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I have to admit, the first time I rebuilt a starter I forgot to put back the spring that pulls back the drive gear (for lack of a better description) after you disengage the starter. The armature assembly was just flopping around in there with nothing to hold it back from contacting the flex plate. It was making a helluva racket. It's only a couple bolts holding the starter on, check that first before you dive into something deeper.
Old Mar 26, 2012 | 05:12 PM
chevydrvr's Avatar
Good idea...as soon as I have time!
Old Mar 26, 2012 | 10:15 PM
xxZ28xx's Avatar
Yup you have to pull the trans :P.. its really not that hard, although im extremely determined to get my car done to drive so I kinda didn't care how hard it was. If I can do it by myself no doubt you could.
The best way I can describe the sound is like a shoe tumbling around in the dryer.. but metal. It would come go come go come go.. annoying. Mostly when it was at an idle though. Thats when it was worse. A good way to check if its cracked is loosen the bolts from the torque converter and see if you can move the flex plate left to right.. then its cracked ;D
good luck!
Old Mar 27, 2012 | 06:24 AM
chevydrvr's Avatar
The weather today is freezing after our 80 degree weather! Love New England. So I'll have to wait.
3rd gen money
Oct 11, 2019 09:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
