I need help fast!!
Car: 92 Z28.. 2010 Silverado Z71
Transmission: 700r
I need help fast!!
My wife put her car in a canal tring not to hit a deer (I know, she should have hit the damn thing.. Lol). So now my project car has to get on the road. 92 tpi. I had a hard time getting it to start. When I finely got it fired it would run like crap for a lil while then would get better. Then a few days ago it stopped running all together... After I put a fuel cleaner in it... I replaced the fuel filter, and while it was off I put a bottle on the fuel line and turned the key. Gas came out about as hard as one would pee. I then put in a new fuel pump. It ran on the first try. But only for 30 sec. Then would not start again. Now it will only run if I use starting fluid. I need help
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: I need help fast!!
purge your fuel line also... You could have air in it (if its EFI)... I had that issue before
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
How old was the crappy ethonal gas? It only last about a month then turns the color of pee.
Transmission: 700r
Transmission: 700r
Car: 1987 iroc
Good, but how old was the gas that was in there? Also what is your fuel pressure? Should be around 43.5 lbs with the vacuum line unplugged (while it's running of coarse) Not sure what it should read with just the key on. someone chime in or do a search.
sreZ28
Oct 22, 2015 08:21 AM
