engine won't stay running
Old Apr 1, 2012 | 05:58 PM
Jesse Boggess's Avatar
Car: 1992 Camaro RS
Engine: '78 L82 bored .30 over
I have a 1992 RS with a 350 and edlebrock carb and manifold. I have been having problems getting it to stay running @ low idle. It starts fine and runs at high idle 3000-3500 rpm and once it drops down to 1500-2000 rpm it will run for a few seconds then stall. There is white smoke that does smell rich of gas.
Things I have checked and replaced
-electric choke was not connected, so I connected it and it doesn't seem to work. Must be broken.
-installed new fuel filter.
-check distributer firing order and all is good
- tightened the manifold mounting bolts and cured any leaks.
- adjusted the fuel and air intake screws, they are both out 2.5 turns at the moment. Check them for dirt, clean as could be.
If anyone has any advice on how to overcome this issue, let me know!
Old Apr 1, 2012 | 06:04 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: engine won't stay running
If the choke isn't working that would be a place to start. If it is stuck in the cold position it will run rich.
camaro11j
Sep 19, 2018 08:49 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
