after a looong hiatus
Old May 3, 2012 | 07:19 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
Hi all, its been quite a while since I've posted here but I've never forgot this site
anyway I'm to this point
and I'm wondering the best way to go about cleaning the engine bay up. both wiring wise and actually scrubbing the grime off wise. at the moment I don't have access to running water but that should change in the near future.
thanks all
Old May 3, 2012 | 08:32 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Re: after a looong hiatus
without water I'd say it can't be done.
But when you get water, pressure wash (a good pressure washer not those little electric things - I use a 3200psi/4-5 gpm) off the thick stuff down to the paint/metal and use Purple Power degreaser. Disclaimer: Don't get it on you anywhere and wear goggles and gloves etc. It will take the oils out of your skin which is a bad thing and will blind you.
Or you could use oven cleaner but that will take paint off. I don't recommend that near anything you like with paint. I have used it to degrease with great results. Disclaimer: Don't get it on you anywhere and wear goggles and gloves etc. It will take the oils out of your skin which is a bad thing and will blind you.
Oven cleaner is great for getting grime off.
On the wires buy some plastic wire loom and stuff them in it like the factory did. Wires that need to go to the starter wrap with something heat resistant.
bonesbrakr
Jan 18, 2015 05:38 PM
Flightoficarus
Aug 24, 2014 08:29 AM
Flightoficarus
May 20, 2014 09:19 AM
88TransAmGuy
Members Firebirds
36
Apr 17, 2014 12:24 PM
fireturd350
Dec 14, 2001 07:14 AM
