quik rookie quest
Old May 5, 2012 | 09:49 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
quik rookie quest
one quick quest. and I'll be out of iyour hair:
I have a 40 over 350 fresh build has not been fired since out the shop. flattop pistons, flattappet cam,and lifters,and self alining flattappet rockers, vortec heads and will have edelbrock 750 carb. with edelbrock performer rpm intake. what oil should I be using for breakin? I have no idea what to look for I was told something aboujt zinc content but someone please enlighten me. I'm ready to start oiling and priming the engine.
Old May 5, 2012 | 10:00 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: quik rookie quest
i use valvoline non senthtic...sinthetic??? lol nope i cant spell it. i dont like multi wieghts but they are ok. after a couple of hours i would change the oil. never heard of any problems from changing the oil too often.
Old May 5, 2012 | 10:08 AM
Car: 91RS
Some quik pics of my baby. and thank you for the quick resoponse.
Attached Thumbnails quik rookie quest-img-20120425-00119.jpg   quik rookie quest-img-20110829-00030.jpg   quik rookie quest-img-20120425-00121.jpg
Old May 5, 2012 | 11:07 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Here is a link with good info on oil. Even though it is at a motorcycle site it discusses oil formulations.
http://www.motorcycleanchor.com/moto...to/mc_oil.html
Pretty much don't get a cheap oil. When I worked at Exxon Port Allen Lubes plant (in the lab) there was a regular grade that had less additives in it as compared to their HD grade. The cheaper was also marketed under the Dollar Store brand. I also tested some Pennzoil and it compared to the HD grade. Usually an oil graded for diesel engine use is HD. Multi-viscosity oil is a good thing and is recommended by all manufacturers that I know of.
Old May 7, 2012 | 08:14 PM
Car: 91RS
ohh crap I messed up and now I need more advice. I can't remember how to attach the serp assem. I mean that i cant remember where the bolts vs. the studs go to hold it all togeether. YES I am a rookie and where do I order a smog ddelete pulley from? thx
Old May 7, 2012 | 09:17 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Amsoil makes a High Zinc break-in oil... get it and use it lol...
Old May 7, 2012 | 09:18 PM
Car: 1988 Iroc-Z
I dont THINK you need a pulley, just a shorter belt...
Old May 8, 2012 | 05:36 AM
Car: 91RS
amsoil and a shorter belt ok no problem. now can someone tell me where the bolts and studs and go that hold the serp. assm onto the engine?
Old May 8, 2012 | 08:15 AM
Car: 1988 Iroc-Z
atcflyboy02@gmail.com ... take some 3' pics of the front of the engine and I'll help you out man...
Old May 14, 2012 | 02:10 PM
Car: 91RS
I asked this question in the tranny section and haven't gotten a response so here goes. I am going from a 89 305tbi with 700r4 to a 69-78 vortec 350carb with a 700r4 now I need a flexplate and starter or will my 89rs starter work with this combo
i found this one from summit will this work and will my 305 starter work with this flexplate ( http://www.summitracing.com/parts/AA...n/?prefilter=1) or do i need this one? and what is the difference? the real ddifference? http://www.summitracing.com/parts/AA...n/?prefilter=1
Old May 14, 2012 | 02:29 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
flex plate and starter should be the same
Old May 14, 2012 | 03:32 PM
Car: 91RS
so which one of these flexplates will work?
Old May 14, 2012 | 03:37 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
69-78 flexplate will work.
Old May 14, 2012 | 03:40 PM
jas2730's Avatar
also, summit has the smog delete pulley for $49.95. I just bought one myself.
Old May 14, 2012 | 03:41 PM
Car: 91RS
thanx man i guess there is no difference in the number of teeth?
Old May 14, 2012 | 03:49 PM
jas2730's Avatar
I believe the difference between a pre 87 and post 87 flexplate is in the spacing of the bolt holes. Since your using a pre 87 block you'll need to use the flexplate from that engine.
Old May 14, 2012 | 04:12 PM
Car: 91RS
thanx
1986Z28OWNER
Dec 13, 2015 10:19 PM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TheExaminer
Sep 6, 2015 11:40 PM
apie2546
Sep 5, 2015 07:40 PM
