82 pontiac wont crank anyone with a starter circuit diagram???
Old May 6, 2012 | 02:57 PM
kitt_2000's Avatar
82 pontiac firebird. i get no power to the starter and the ignition key doesnt feel like it is turning to the start position... it has a brake pedal shifter mechanism connected to the steering column.. anyone got any wire diagrams or anything that could help me out??? thanks..
Attached Thumbnails 82 pontiac wont crank anyone with a starter circuit diagram???-img_1998.jpg   82 pontiac wont crank anyone with a starter circuit diagram???-img_1997.jpg   82 pontiac wont crank anyone with a starter circuit diagram???-img_1996.jpg
Old May 6, 2012 | 08:27 PM
Re: 82 pontiac wont crank anyone with a starter circuit diagram???
Doesn't sound like the type of problem that a wiring diagram would be helpful for.
Fix the mechanical breakage first.
Old May 6, 2012 | 09:02 PM
kitt_2000's Avatar
well i worked on the car all day today again.. i found that the yellow wire from the ignition switch goes to the neutral safety switch. it doesnt power up when the key is turned to the start position. i put power to the purple wire on the neutral safety switch and the engine starts. Now i need to adjust the ignition switch i guess. anyone know how to adjust the ignition switch so that the rod pushes enough to the start position??
Old May 7, 2012 | 05:56 AM
Pretty straightforward... loosen the 2 screws that hold it to the column, slide it up or down along the column as required, tighten back down.
Old May 7, 2012 | 10:41 AM
kitt_2000's Avatar
thanks guys i got the ignition switch figured out.. i did just that, lowered the column and adjusted the switch.. but i still have a brake interlock problem that i cant figure out. key wont come out sometimes and shifter wont come out of park. for now i have the interlock cable disconnected but cant get the key out.. anyone know how the interlock wires do or how it works??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
