Whats this
Old May 12, 2012 | 10:13 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Whats this
some sort of ground
Size:  229.1 KB Smog Pump... where does that connect to?
Small cable... dunno what it is... thanks for the help
Old May 12, 2012 | 10:21 AM
conlinj's Avatar
Re: Whats this
First pic engine ground, needs to attach to the back of the cyl head.
Second pic, look for the part of the air system that doesn't have anything connected to it (the crossover pipe from the driver side manifold, the down pipe to the converter or the pass side manifold)
Third could be the vacuum hose that goes to the heater diverter valve, hard to tell from that pic/angle
Old May 12, 2012 | 10:22 AM
Re: Whats this
1. should go to a bolt on the rear-facing surface of the pass side head
2. hard to tell which one it is for sure, but either goes to the AIR pump, or to one of the AIR check valves
3. vacuum line in HVAC system; could be either the "supply" line, or the one to the heater control valve
Old May 12, 2012 | 10:26 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
could this ground be giving me CEL codes?
Old May 12, 2012 | 10:32 AM
conlinj's Avatar
Re: Whats this
possibly, hook everything back up, clear the codes and drive the car see if they come back
Old May 12, 2012 | 10:34 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
im getting knock sensor..... EGR and O2 sensor.... lets see if this fixes the problems =/
Old May 12, 2012 | 10:54 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
I cheated... I conected the wire to valve cover nut... I have the fuel ground the same way
Old May 12, 2012 | 11:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Whats this
That kinda works but fix it properly soon.
Old May 12, 2012 | 11:25 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
mmm i cant reach back there.... big hands
Old May 12, 2012 | 11:33 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Whats this
Needs to connect to a firm bolt on the block/heads that won't come undone; vc nuts tend to back off over time.
Old May 12, 2012 | 11:34 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
ill just re tighten them once in a while
Old May 12, 2012 | 12:09 PM
TTOP350's Avatar
Re: Whats this
Yeah its a very tough spot to work in. I get em from the bottom with the trans Xmember undone.
That air tube also goes to the ground stud on the back of the head.
Old May 14, 2012 | 02:46 PM
Cleric69's Avatar
Car: '87 IROC-Z
Engine: 350ci
Transmission: 700r4 rebuilt
Re: Whats this
My ground is just connected to the rear-most header bolt. Of course I have no smog/AC/heater/kitchen sink to get in the way...
Old May 17, 2012 | 11:30 AM
eighty8's Avatar
Car: 1988 IROC-Z
Engine: 305 TBI
Transmission: TH 350
Re: Whats this
Is the last one a small cable or a vacuum line. If it's a vacuum line check this out https://www.thirdgen.org/forums/tbi/...egr-valve.html scroll down and find the diagram
Old May 17, 2012 | 11:33 AM
pvr007's Avatar
Engine: 305 TBI
Re: Whats this
Suposedly thats for an automatic... 5 speed require a t for the air pump
Old May 17, 2012 | 11:44 AM
eighty8's Avatar
Car: 1988 IROC-Z
Engine: 305 TBI
Re: Whats this
My bad, didn't notice you were rockin' the stick
