Passenger Cyl Head Sensor
Old May 14, 2012 | 08:14 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Does anyone know what sensor goes into the passenger side cyl head towards the rear of the engine? Had my heads redone and they came back with no sensors and I don't know what to tell the parts guy at the store.
Old May 14, 2012 | 08:33 PM
Re: Passenger Cyl Head Sensor
Fan switch
Old May 14, 2012 | 09:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
acdelco 15-4373 gm#10045782
Old May 14, 2012 | 11:00 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Are there 2 fan switches then? I already have one on the front of my intake maniold.
Old May 14, 2012 | 11:18 PM
Engine: Lb9
Transmission: M20
That is the ect sensor for engine coolant temp feedback to the ECM.
Old May 15, 2012 | 01:33 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Im pretty sure that sensor is in the front of my manifold as well. The connector that goes into the sensor im missing looks just like the knock sensor connector that goes into the bottom of the block below it.
Old May 15, 2012 | 02:01 AM
Engine: Lb9
Transmission: M20
The cts looks different and is a 2 wire thermistor acdelco 213-928 gm#15326386
you could repair this with a gm 12101899 and the fan switch would be gm 12102621 or acdelco PT308
Old May 15, 2012 | 02:02 AM
Engine: Lb9
Transmission: M20
HTH !
Car: 92RS
Engine: LQ4
Transmission: 4L80E
this is a one wire sensor
Old May 15, 2012 | 02:09 AM
Engine: Lb9
Transmission: M20
so it is not like post 3 ?
Old May 15, 2012 | 10:06 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
You should have three sensors. Fan switch in passenger side head. Dash gauge in driver's side head, and ECM in the intake manifold.
Old May 15, 2012 | 10:36 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
okay okay, i have figured this situation out. My fan was not working properly a few years bad and my mechanic ran a new fan switch on my manifold with a new wire all the way to the relay and just left the old switch in the cyl head inactive. Sorry for the confusion but thanks for helping me out!
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
fasteddi
Sep 2, 2015 10:29 AM
