Timing Help Please
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
Timing Help Please
Hey everyone im trying to adjust my timing on my 91 Camaro RS and i got it running somewhat decent but under load it gives me **** and pops and backfires, what to the points above the harmonic balancer stand for? and what timing does it need to be set too, its a 305 with toilet bowl injection
ANY HELP will be greatly appreciated
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Timing Help Please
I don't know right off hand what your timing should be, some one will help you or what I have done in the past is call your local parts store.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Here's an article from the technical articles section. Lots of good stuff in there, you should go check it out. Have fun!
https://www.thirdgen.org/settingtiming
Car: 1991 Camaro RS
Axle/Gears: Factory
I have gotten the car running somewhat ok now, its timed at 10.5 degrees between the last two points. This is the best i can get it to run but there is still a missfire. I cannot figure out why but when i get into it round 3rd gear service engine light comes on and it gets terrible and wants to shut off. could it be a bad plug? or maybe the disributor is a tooth off? PLEASE GIVE ME IDEAS!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 82 Z28
Transmission: T400
Car: 1991 Camaro RS
Axle/Gears: Factory
Yes i did unplug the ecm before setting base timing, and I understand i need to read the codes, where do i put the paper clip?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Car: 1991 Camaro RS
Axle/Gears: Factory
OK so i figured out what the problem was all along, For those of you out there who need help here it is. The ECM wire on 90-92 cars is located on the passenger side under the hood next to the heater box...NOT on the back of the distributor which is the same color wire. The timing tab has a big open V followed by 3 little vs in it. the center of the big V is 0* and towards the passenger side is before top dead center counting int intervals of 2* Set it to 6* plug the ECM back in and problem solved. Thank you for all of the people that pointed out some things to look at!
