Where To Buy VATS Lock Cylinder/Is This It?
Car: 90 Camaro IROC-Z
Engine: L98 350
Axle/Gears: 3.23 posi
VATS is pissing me off. Its doing that won't start crap every now and then but will start after 5 minutes of cursing/waiting. The lock cylinder is all worn and crap plus the key comes out of the cylinder while the car is on and running. So I am replacing the lock cylinder but don't know where to find a VATS one. I found a couple places that say they have cylinders that are for my car but it doesn't say if its VATS or not. I found this cylinder that seems like its the right one but idk for sure. Its Standard Motor Products Part #US161L. Help please.....
Engine: L98 350
Re: Where To Buy VATS Lock Cylinder/Is This It?
Engine: L98 350
For anyone wondering, yes the part # above is the correct one for an automatic. Has the VATS contacts and dummy keys.
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
I replaced mine in January due to lost ignition key. BWD CS421L is the one i got from O'reilly Auto Parts for $55.00. It is a pain in the butt to get the wires down through the column without pulling the connection clip off imo.
As far as i can tell by looking, the part you listed is the correct one.
Any other questions about doing this let me know. I have a few pictures i took of the steps and what the column looks like when being torn down.
Also imo. VATS is far too valuable. Even though my car is beat all to hell and has a bullet hole... it's still a thief magnet. Broken into 3 times in 5 years. You'd think that peeps would know you can't steel this car without a tow truck!
Engine: L98 350
Car: '91 Formula
Engine: 305 TBI
Keep in mind i have a '91 firebird but i would think they would be close enough. Sorry no pic of the steering wheel puller. I was in a hurry and tired of messing with the thing. =)
Car: '91 Formula
Engine: 305 TBI
Make sure these parts are snug or you'll bend them when you put the lock plate back on and have to new ones at a junk yard cuz they are discontinued.
I know that firebird steering columns are compatible through at least 1995 (I had to get another lock plate and the parts pictured).
Hope this helps or at least saves you a headache. There are other step by step instructions on here but i don't remember where they are.
OH! Another piece of advice. If you've never removed a steering wheel. It should pop right off. If it doesn't you'll bend a screw on the puller, this means it isn't on right. My wheel was very temper mental. One time it would come right off, another it was very stubborn. Remove the puller and reconnect it and keep doing that until it works with little effort.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Mackadoches, since you need to figure out the idle issue with the car it is easy to reprogram out the vats.
Engine: L98 350
Yeah I know a lot of people like to bypass or remove it in some form of fashion, however i am probably one of the few who actually want to keep it. I just need it workin properly.
Engine: L98 350
And thanks a lot 91specialk! The pics help alot. Ill go search for the instructions....hopefully my haynes manual has some in there too.
