What kind of gas?
Old May 28, 2012 | 07:21 PM
orangek's Avatar
What kind of gas?
So, today I bought my first car, a 1991 Camaro Z28, 305. I was wondering what kind of gas you guys use, regular or premium? And if you do use premium, would it still be ok to use regular? I'm asking this because premium gas is $4.00 a gallon where I live, and don't want to pay that much for gas if it's not needed. Thank you.
Old May 28, 2012 | 07:29 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: What kind of gas?
89
Old May 28, 2012 | 07:46 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I use Premuim a lot of the time but seems to run the same on regular. Our regular here is 87 octane and premium is 89 (I am 99% sure). I don't notice any differences, I just use premium because less carbon build up and I FEEL it is better for the injectors. Our cars do not say Premuim fuel only anyplace I have seen.
Old May 28, 2012 | 07:50 PM
orangek's Avatar
So it is fine to use regular? I don't want to make the car run not as well, but if there is no difference in performance I'd like to save some money.
Old May 29, 2012 | 03:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You should be fine on the 87 Octane. If it starts to pin/detonate, bump it up to the 89. I run 90 here and don't have any problems with my mild build 355.
Old May 29, 2012 | 10:32 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
On a related note, what brand of gas do you guys use? Ive always used shell and marathon, my dad says sunoco is the best. Shell has always seemed to run the best in my cars, so i try to stick with that.
Is there one brand that runs better in TPI engines?
Old May 29, 2012 | 10:44 AM
ghost91's Avatar
Car: 1991 Camaro Z28
i use 89-93 octane. and i feel that sunoco runs the best. next best....probably hess. but their expensive.
Old May 29, 2012 | 10:52 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
BP or Shell 93 octane.
Old May 29, 2012 | 11:09 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I run 93 in my car just to be safe as it's 25 years old and i don't drive it all that much. On a side note I will not run BP gas in my lawn mower.
Old May 29, 2012 | 11:49 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I personally think you folks with relatively stock vehicles are completely wasting your money by running premium gas. Run the lowest octane you can... Your car will be happy and your wallet will be happy. It's win/win.
Old May 29, 2012 | 12:14 PM
Ozz1967's Avatar
Car: 1984 Trans Am
:YUP:
These cars run a best 9:1 compression if you have a fresh stock rebuild and on 87 octane will be completely happy.
Not sure of the brand i use here, but when I was in the states, I'd use AMOCO if there was one, otherwise Texaco/Conoco but truth be told, once you get down to it, gas is like oil you buy. It's all basically the same.
Old May 29, 2012 | 12:24 PM
Black88Z's Avatar
LMAO, thats great. I try not to use BP either. Just not a big fan.
My engine is fairly stock, and i use 87. I personally agree with what was said about it being a bit over kill for a stock engine to use anything above that.
Old May 29, 2012 | 08:47 PM
orangek's Avatar
As of right now I use Turkey Hill gas in my Grand Am since I get 10 cents off every gallon. I am picking up my Camaro at the end of the week, so I guess I will have to experiment with a few different stations.
Old May 29, 2012 | 08:57 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I run mid grade in my IROC. If I run regular it pings. It doesn't matter what brand I use either.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
earlpote
Sep 12, 2015 11:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
