alternator prob....
Old May 30, 2012 | 02:11 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
alternator prob....
I put the positive conn wires on the rear bolt that goes in the alternator, the bolt came out, and now it won't go back in!!! Alternator was rebuilt last mid summer, bolt is not stripped. Just seeing if anyone has any info or suggestions. Any help is greatly apreciated! Its an 84 T/A with 305 H.O.
Old May 30, 2012 | 03:34 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: alternator prob....
Are the threads on the inside, where the bolt goes into, ok? My first guess, they'r boogered up.
Old May 30, 2012 | 03:44 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
They seem fine, it was fine untill i tightened the nut to the end....has me confused?!!
Old May 30, 2012 | 09:08 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
you will have to take the alternator halves apart and
reinstall the nut on the end of the output stud-an
alternator shop can do this or you can do it yourself if
so inclined-pretty easy,but certain precautions should
be taken to avoid damage to brushes or stator winding.
I f you want to do repair yourself,i can give more
specific details
Old May 31, 2012 | 03:47 PM
Michael21's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
absolutly right!!!!! thanks, its back on the car and fixed. Thanks for the help.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
