Intake Manifold Swap
Old Jun 13, 2012 | 05:15 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
So if I swap the manifold can I still use the stock EGR? or do I have to do an EGR delete? and if so does that affect the mileage too much?
Old Jun 13, 2012 | 06:13 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Intake Manifold Swap
I believe Eldabrock [spelling] makes a manifold that will use your stock EGR.
Old Jun 13, 2012 | 06:16 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
can I use the rochester on it though?
Old Jun 13, 2012 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
ESP doesn't work well on the internet .......
Be nice if you told us WHAT manifold you are talking about ?????????????
Old Jun 13, 2012 | 07:00 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
an egr edelbrock
Old Jun 13, 2012 | 07:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
an egr edelbrock
You mean a Edelbrock Performer ?
The one that shows 2 carb bolt patterns to take either squarebore or spreadbore carbs?
Old Jun 13, 2012 | 07:42 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
http://www.summitracing.com/parts/EDL-3701/
Yeah. The rochester is a spreadbore. Also.... Can I use a http://www.summitracing.com/parts/MSD-8360/ distributor with a rochester? its mechanical and vacuum advance according to the discription...
Old Jun 13, 2012 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Like I said ; a Edelbrock Performer intake
Can I use a MSD-8360 distributor with a rochester?
You could but a MSD # 8362 is half the price and includes the coil
http://www.summitracing.com/parts/MSD-8362/
Old Jun 13, 2012 | 08:18 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
thanks for the advice!
Old Jun 17, 2012 | 09:54 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
so the instructions are confusing... http://static.summitracing.com/globa...0427012716.pdf
I dont know if I need the throttle linkage and all that.... and it says something about only fitting 87-up aluminum heads
Old Jun 17, 2012 | 11:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So buy a #2101 if you have early heads
http://www.summitracing.com/parts/EDL-2101/
Neither do we since you have not mentioned any details about what intake setup ( if any ) you are swapping from ?
As I said earlier ; ESP doesn't work well on the Internet ;
you have to give us SOME INFO
Old Jun 17, 2012 | 11:36 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
its not EGR'ed
Old Jun 18, 2012 | 12:06 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
its not EGR'ed
Summit state the # 3701 intake fits SBC heads up to 1987 and has EGR ;
so WHAT is your problem with it ?
Old Jun 18, 2012 | 12:12 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Performer - ‘86 and Earlier: For 1955-86 262-400 c.i.d. small-block Chevy. Performer manifold
2101 Includes provision to add oil fill tube. Not for Chevy Bowtie heads. Will fit 1987 and later
stock aluminum heads. 3701 includes provision for EGR.
^ not very clear.... >.>
Old Jun 18, 2012 | 12:39 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
they go like 3 directions with it.
Old Jun 18, 2012 | 02:10 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Will fit 1987 and later stock aluminum heads. .
Perfectly clear.
But of no concern to you unless you have '87 or later factory (Vette ) Alum heads ??????
The # 3701 intake will fit those Vette heads and any factory cast iron heads before 1987 because they have the same bolt angle
Cast iron heads after 1986 take #2104 and # 3706 (EGR ) intake because they have a different bolt angle
And '96 + Vortec heads are different again
Old Jun 18, 2012 | 02:13 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
and trick flows are the same angle as stock? (the heads)
Old Jun 18, 2012 | 05:06 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Which STOCK, early or late?
TFS heads available as direct replacements for early or late style Gen 1 cast iron heads
Old Jun 18, 2012 | 07:22 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
86...
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
