Speedometer PROBLEMS
Old Jun 14, 2012 | 10:12 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
I've searched but haven't been able to get a clear answer.
Speedo & tach are way off. For lack of better wording, they both seem to keep spinnin till they max out..
I would hate to have to purchase a cluster.
Any ideas or info would be greatly appreciated.
Thx
Old Jun 14, 2012 | 11:53 AM
88 Z-ROC's Avatar
Re: Speedometer PROBLEMS
For instance .. I'm driving about 40 MPH and speedo reads 90 and just keeps going up till it hits the 145 mark
Old Jun 14, 2012 | 07:55 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Maybe tire/rear gear combination, are you sure the gears havent been changed?
Old Jun 14, 2012 | 08:10 PM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
this is a very typical problem with the third gen series cars. mine for instance is only the rpm gauge, which reads 2500 at idle and 6500 at 55mps in 5th(5 speed 305) there is a post some where on this site to remedy it. if i remember correctly, they had to change a resistor or something in the cluster.
Old Jun 14, 2012 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
how long have you had the car?
Is this a recent development?
Old Jun 14, 2012 | 08:13 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Camaro RS
this is a very typical problem with the third gen camaros.
there is a post some where on this site to remedy it..
The problem is common to the 90 -92 speedos like your car
https://www.thirdgen.org/forums/elec...meter-fix.html
Given he has both tacho and speedo problem which are completely separate from each other wiring wise ,
I suspect his problem is within the cluster itself ( or it's grounds )
Old Jun 14, 2012 | 08:16 PM
88 Z-ROC's Avatar
Since 11/11
I was "hot wired" (wires soldered to circuit board)
I replaced the unit and also replaced the speedo cable.. and now it goes crazy.
Old Jun 17, 2012 | 01:36 AM
Zeeboinc's Avatar
Car: '89 Iroc Z
Engine: Paxton SN-92 305
Transmission: 5 spd
Could be your speedo cable, the one from the tranny to the speedo housing (or in my case from the tranny to the step-down box then to the speedo housing). The cable could be old and weak or could have loosened off of the tranny threads.
Old Jun 17, 2012 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Jun 17, 2012 | 11:07 AM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
I had a similar issue with my '99 Chev 2500 van. The speedometer would read over 100 mph when actual speed was probably only 35. The pre-set speed limiter would cut the engine at that point.
It turned out to be the ECM. There was a break in the seal and moisture caused corrosion of the aluminum case which led to white powder on the circuit boards. Add humidity and something was shorting out giving false readings from the didgital speed sensor.
Put in a salvage yard ECM and the problem was gone.
Old Jun 21, 2012 | 02:44 PM
88 Z-ROC's Avatar
I noticed the trip was not functioning properly..
I reset to zeros drove a mile and had 900 miles on trip..
I will have to look into it..
Thank for all the responses .. Its much appreciated
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
