Broken sensor on bottom of engine bLock?
Old Jun 16, 2012 | 01:04 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
I have a Iroc 305 tpi and inwas under my car when I noticed a broken and torn wire that was missing a harness of some sort. I can't figure out what it connects too because everything broke off and the only thing left is the wire with a weather connection. The connection location is right under the engine dipstick and No it is not the knock sensor my knock sensor is connected. Help guys every mechanic I go to can't figure it out.
Old Jun 16, 2012 | 01:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Broken sensor on bottom of engine bLock?
What color is the wire ?
Old Jun 16, 2012 | 01:47 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
The wire is black
Old Jun 16, 2012 | 01:51 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
The wire is black
Does the wire lead to a connector, that is running through a metal holster?
Old Jun 16, 2012 | 02:02 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
It goes to a plastic connection but the whole peice is missing I can only tell u that it connects to a plastic
Old Jun 16, 2012 | 02:19 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Can you take a light and shine it on it, and take a picture?
Sounds like a knock sensor man.
Old Jun 16, 2012 | 02:22 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Ok I'll take it tommorow
Old Jun 16, 2012 | 02:52 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The knock sensor mounted in bottom of the block
Old Jun 16, 2012 | 03:01 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Yeah I know, But he's saying its not leading to the knock sensor? I'm trying to visualize what else it could be.
Old Jun 16, 2012 | 03:23 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
To be honest with you I don't even kno if it's a sensor for sure but something was connected to that area if u follow the engine dipstick allthe way down and the way it curves you will see the connection. What ever is in that area that's what it is but it's not the knock sensor.
Old Jun 16, 2012 | 03:26 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Positive its not leading to the starter?
Or the power wire leading to your ecu?
Old Jun 16, 2012 | 03:59 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Doesn't go to the starter. Is there a tempature sEnsor around that area or what else is around that are other than knock sensor bcus I can't find anything in the books.
Old Jun 16, 2012 | 06:37 AM
Damon's Avatar
The connectors on the Knock Sensor and Cooling Fan Switch wires are physically idential, just the color is different. Fan Switch is up higher, though- in the pass. side cylinder head between the two rear saprk plugs.
The Fan Switch plug and connector are amongst the most commonly mutilated electrical connectors you find on 3rd gen F-bodies.
From memory, I think the KS wire is black and the Fan Switch wire is white or tan. I recall the colors being the same on the sensor/switch connector and the plug that goes on it (GM giving you a little hint which one goes where). I've even seen them mistakeny interchanged with eachother on occasion (including when I did it once and couldn't figure out why the fan would never kick on!).
Old Jun 16, 2012 | 06:50 AM
stubby1962's Avatar
Car: 1989 IROC-Z
Maybe the cooling fan temp switch..Does your fan come on like it is suppose to?
Old Jun 16, 2012 | 01:56 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
It might be tempature switch bcus I had wire connected to the fan automatically to come on when I turned the key bcus it was coming on late and sometimes it wouldn't come on. Can this cause chEck engine light to come on bcus my light is not on?
Old Jun 16, 2012 | 09:33 PM
stubby1962's Avatar
Car: 1989 IROC-Z
Disconnect your wire that makes your fan come on. Turn your key on and ground the loose wire to the block and see if your fan comes on. If so, it goes to the temp cooling switch..
Old Sep 16, 2012 | 01:23 AM
Nelz's Avatar
Go to the library. Download a scanning app on your iphone. Get the pin out diagram for your model year and scan the page. If you need it for a 1988 Camaro, let me know. I do not know how to upload a photo as it is asking for me to link it.
Old Sep 16, 2012 | 02:06 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
That is a knock sensor.. You are stating yours is already hooked up... Take a picture of the one you say is hooked up..
Old Sep 16, 2012 | 06:58 PM
Nelz's Avatar
It's the heavy duty coolant fan switch. Pin D11
Old Sep 16, 2012 | 07:06 PM
Nelz's Avatar
i pulled out the sensor and it had GM 5782 on it. It looks like a coolant temp sensor in the head
Old Sep 17, 2012 | 12:56 AM
Nelz's Avatar
http://www.rockauto.com/catalog/moreinfo.php?pk=84272
Old Sep 17, 2012 | 01:37 AM
Nelz's Avatar
http://www.hawksthirdgenparts.com/pr...52d92-TBI.html
There's the connector
Old Dec 22, 2024 | 07:00 PM
881SA's Avatar
Car: 1988 Camaro Z28
Engine: 5.7 / L98
Axle/Gears: 3.27 BW
Any ideas were to find one of these sensors now?
Old Dec 22, 2024 | 07:58 PM
Parts store
Old Dec 22, 2024 | 08:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wells sw555 works good
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
