86 iroc tpi idle
Old Jul 3, 2012 | 07:45 PM
cyrus145's Avatar
86 iroc tpi idle
hi,
I have a 86 iroc z, that idles high. i was getting codes 22 and 44. So I replaced the tps, now it tries to idle at 650-700 but is very tough and it either tries to die or kicks the idle back up to around 1500. my only guess now it's that it's either the IAC, EGR, or oil pressure sensor. am I barking up the right tree or way off? any imput is greatly appreciated.
Thanks, cyrus
Old Jul 3, 2012 | 08:00 PM
Seanphelps321's Avatar
Car: 1992 Firebird
Engine: 3.1L(swapping in 385)
Transmission: Looking for T56
Axle/Gears: Looking for 3.73 posi
Re: 86 iroc tpi idle
Originally Posted by cyrus145
hi,
Thanks, cyrus
I had a problem similiar to this and it ended up being a vacuum leak with worn out O rings. I had thought it was the IAC and I think I replaced it which actually helped a little but would still idle up to about 1500 and then drop back to about 700. I replaced the O rings and it was back to normal. You'll probably get better answers from the guys on this site, but it may be worth a shot to spray carb cleaner to find a vacuum leak.
Old Jul 3, 2012 | 08:16 PM
cyrus145's Avatar
I should've mentioned it is fuel injected with the tpi, unless you knew that. Anyway where to you spray the carb cleaner to find your leak? The way it idles so rough makes me think its choking itself out. But I don't really have much experience with these camaros, so I'm somewhat clueless.
Old Jul 3, 2012 | 08:31 PM
Car: 1992 Firebird
Where ever you spray, if the engine revs up then the vacuum leak will be in that area. I sprayed carb cleaner on all of the intake and it revved up when I sprayed under the plenum. I ended up spraying directly onto the injectors and when I sprayed, the RPM raised significantly. So I popped off the upper intake plenum, pulled out the injectors, and replaced the O rings and it idled perfectly after that.
Old Jul 3, 2012 | 08:34 PM
Car: 1992 Firebird
Also, about the codes, this may help:
http://gmtips.com/3rd-degree/dox/tip...es/code-01.htm
Old Jul 4, 2012 | 01:33 AM
cyrus145's Avatar
yeah i have that link bookmarked, I tried the the carb cleaner, and it did exactly what you said happened to you. so I think I might try the O-rings on the injectors.
Old Jul 4, 2012 | 09:56 AM
Car: 1992 Firebird
Hopefully that'll fix it. If not, replacing O rings is quick and cheap. Let us know what happens.
Old Jul 4, 2012 | 10:45 AM
cyrus145's Avatar
I'm hoping so I won't be able to get to it til friday morning, but I will let you know. I appreciate the help, thanks a lot.
Old Jul 7, 2012 | 10:47 PM
cyrus145's Avatar
Well, I pulled the fuel rails and everything else off today, the o-rings are horrid. But what is the most ugly part about it is all 8 injectors are falling apart. I'm guessing this might be my problem, but I wont know for a week or two. I guess the autopart stores around here dont keep 8 injectors in stock, so i'll be waiting for them to arrive.
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
squiggy2
Aug 9, 2015 09:30 PM
