Part fell off - anyone know what it is?
Old Jul 7, 2012 | 08:10 AM
Trelane's Avatar
Car: 1991 Pontiac Firebird 3.1 V6
Hey,
I've got a 1991 Pontiac Firebird, 3.1 V6.
Recently in reverse after a little bit of a drive it has been stalling, its also struggling in neutral and i've noticed its now struggling when coming to a slow down in any of the 'gears'.
Just pulled it onto my drive and i noticed a part on the drive.
The part is:
http://images.y4food.co.uk/part1.jpg
http://images.y4food.co.uk/part2.jpg
Anyone have any ideas can you let me know?
Thanks,
Old Jul 7, 2012 | 08:32 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Part fell off - anyone know what it is?
Hard to tell, but it looks like a sway bar end link, or what is left of it.
Old Jul 7, 2012 | 08:35 AM
Trelane's Avatar
Ah, i guess this cant account for the stalling though?
Any ideas about why its having trouble idiling?
Old Jul 7, 2012 | 08:43 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Maybe a good tune up?
Old Jul 7, 2012 | 08:44 AM
Trelane's Avatar
yeah, maybe, i just want to drive the thing now lol. first it was the battery, then excessive leaking, now stalling and a broken sway bar!
Sway bars cant like make things shudder and cause stalling though can they?
Old Jul 7, 2012 | 08:52 AM
Edwardgp's Avatar
Engine: 454-350
Unless when it broke the part left on the car flew up and hit something.
Trelane's Avatar
yeah, unfortunatly its been a bit off for some time
Old Jul 7, 2012 | 09:22 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's definitely a piece of stab link, and although it has no affect on your stalling, it could affect your safety if you attempt an evasive maneuver without it. it's a cheap part, and easy to change. Do both of them at the same time.
As far as your stalling goes, there are 100 possibilites that could cause your symptoms. You might get lucky if someone guesses right. But tracking down the real problem takes time, which you might not have since you "just want to drive the thing".
Old Jul 7, 2012 | 09:24 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
For the stalling you could try checking for a vacuum leak, or even check the air filter/s to see if it/they need replacing.
Old Jul 7, 2012 | 11:31 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Dirty/faulty IAC - my
Old Jul 7, 2012 | 04:54 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Did you disconnect the battery recently? If so, you may have to do an idle relearn procedure. Same thing happened on my 91'
Old Jul 9, 2012 | 11:17 AM
Trelane's Avatar
Dirty/faulty IAC, whats that?
Hey, Yes i did, the battery was replaced after a prolonged period of battery failure/flatness.
Whats an idle relearn procedure??
Old Jul 9, 2012 | 05:40 PM
antares57's Avatar
Take a look here.
https://www.thirdgen.org/forums/v6/6...bird-3-1l.html
Old Jul 10, 2012 | 11:45 AM
Trelane's Avatar
aha, thanks i'm looking into it : )
Old Jul 11, 2012 | 12:06 PM
Trelane's Avatar
Hey,
Good news, we've discovered the part's off a Citroen.
Thanks again for all the input.
Bad news its missfireing(only when the engine has warmed up) and there's a zzzt coming from behind the engine occasionally, not sure if thats linked to the missfire.
My mechanic seems to think its possibly electrical.
Anyone know anything that this is normally?
Also i'm looking at pulling the error codes out according to:
https://www.thirdgen.org/service-eng...ht-error-codes
My question is: this is a code '12' diagnostic.
flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause
What about this adds up to '12' and by that extent what on earth's a code 13, 14, 15 etc error? Am i missing an obvious sequence?
Cheers,
Old Jul 11, 2012 | 12:23 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
What's to get? 1 flash followed by 2 flashes. Means 12. Afaik, code 12 means all's good and the ecm is working normally (actually means the distrubutor pulse is missing, as it should be with the engine off).
Old Jul 11, 2012 | 12:25 PM
Trelane's Avatar
oh lol, it is THAT obvious, i was looking for some magical pattern, like sets of flashes adding up to something.
Any ideas about common missfireing only when engine is warm?
Cheers,
Old Jul 11, 2012 | 12:51 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh no worries. Misfiring - the usual suspects - plugs, wires, vac leaks, fuel pressure, ignition module etc etc. Beyond that - did you pull the codes yet?
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
