complete cam kit for 88 trans am gta
Old Jul 15, 2012 | 11:25 PM
streetta's Avatar
Car: 1988 pontiac trans am gta
Transmission: t5
Axle/Gears: 373
I have a 1988 trans am gta.. it is mostly stock, however i have it torn apart and have been doing some minor intake porting and things of that sort. While im in this deep im thinking about a cam kit... the car stock does have a roller cam in it. I did notice that my valve springs are pretty weak and worn out.... I am looking for a complete cam kit i guess is where i am going with this. would i reuse the stock lifters ? if so then maybe i just need a camshaft, valve springs, locks and retainers ? im looking for a street/ strip set up with a decent chopp but not something that is going to be too much for the mostly stock car.( car is a five speed) could i piece a set like this together? am i better with a kit ? cheeeeeeaper the better thanks
Brian
Old Jul 16, 2012 | 06:51 AM
Re: complete cam kit for 88 trans am gta
You don't want "cheeeeeeeeeep". Might seem like a good idea at the time; has a way of coming back to bite you. Of course nobody likes to spend more than necessary, but putting "cheeeeeeeeep" as a primary concern is a mistake.
I don't know of a "kit" that has what you are looking for, and nothing else besides that; so, probably better off piecing it together.
Look at a Comp "501" cam, 981 springs, and the retainers & keepers to go with it. Use positive seals on the intakes, throw away the oil splash shields. If the exh valves have "rotators", throw those away as well and replace with .090" of shims under the springs.
Old Jul 16, 2012 | 02:16 PM
streetta's Avatar
Transmission: t5
Axle/Gears: 373
Ok thanks for that... One more question.. you are going to think im a cheap *** acter this but I have alot of stuff going on right now.. if I sprayed the car and was sure not to rev it real high.. Could the stock cam hold around 300 to 330 HP ? Or is the cam deffinately something I want to do
Posted from Thirdgen.org App for Android
Old Jul 16, 2012 | 08:57 PM
The cam lets in more air, so that you can also let in more fuel.
Nitrous substitutes for more air and adds more fuel to go with it.
Do the math.
Not sure about "hold" or "stuff going on".
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
TreDeClaw
Aug 14, 2015 06:58 PM
gta power
Aug 13, 2015 06:15 AM
