rebuild kit question
Old Jul 17, 2012 | 08:40 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i found a full master rebuild kit online a guy is selling along with alot of other 350 parts including a block and a set of heads. well the kit comes with all the bearings, new sealed power pistons, new oil pump, new timing chain kit, 16 new lifters, but he doesnt have all the gaskets, only the little ones, hes missing the big ones like head, intake, oil pan, ect. well my question is, is this kit worth $100? i cant use the lifters since my block takes a roller cam but can i use everything else on my 96 block?
Attached Thumbnails rebuild kit question-reb.jpg   rebuild kit question-rebu.jpg   rebuild kit question-rebui.jpg
Old Jul 17, 2012 | 08:58 PM
Engine: L31 350
Re: rebuild kit question
got a few more pictures of the bearings, he has two sets of main and rod bearings
Attached Thumbnails rebuild kit question-rebuil.jpg   rebuild kit question-rebuild-k.jpg   rebuild kit question-rebuild-kit.jpg
Old Jul 17, 2012 | 09:00 PM
Engine: L31 350
and the extra bearings
Attached Thumbnails rebuild kit question-rebuild.jpg   rebuild kit question-rebuild-ki.jpg
Old Jul 18, 2012 | 11:05 AM
Engine: L31 350
Bumb
Old Jul 18, 2012 | 06:31 PM
Engine: L31 350
TTT
Old Jul 18, 2012 | 06:53 PM
Seanphelps321's Avatar
Car: 1992 Firebird
Engine: 3.1L(swapping in 385)
Transmission: Looking for T56
Axle/Gears: Looking for 3.73 posi
Wait, so what exactly does the kit come with? Bearing, pistons, oil pump, timing chain kit, lifters, and some gaskets?
Old Jul 18, 2012 | 07:44 PM
Engine: L31 350
Yes, piston rings aswell.
Old Jul 18, 2012 | 07:59 PM
Car: 1992 Firebird
It sounds like a good price to me, although I'm not a professional when it comes to this. Since you're buying it from another guy, is it all new/unused?
Old Jul 18, 2012 | 08:36 PM
Engine: L31 350
Yes, all new never opened besides him taking pictures for me
Old Jul 18, 2012 | 09:28 PM
Car: 1992 Firebird
I saw your thread on your car. This kit is going into the 5.7 vortech, right?
Also, is all of what he has in this kit, did it all originally come as a kit or is pieced together? If it came as a whole kit then what's the kit called, part number would be great. If it's all from separate purchases, do you know the part numbers of the rest or maybe brand?
Old Jul 18, 2012 | 09:37 PM
Engine: L31 350
it was all orignially in a kit, that kit has sence been discontinued from summit but here is the closest match
http://www.summitracing.com/parts/FE...-311/?rtype=10
looks like most of it is sealed power
Old Jul 18, 2012 | 09:50 PM
Car: 1992 Firebird
Yea. Looks like it's a good price. I'm not sure of the quality, could be good or bad. I have a concern with the piston though. Do the specs on these pistons match what you're replacing? If you're not trying to match what you have, then make sure the compression height of the pistons matches and the dish CCs gives you ideal compression.
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
