bigger dual valve springs for 488 cam ?
Old Jul 19, 2012 | 11:49 PM
streetta's Avatar
Car: 1988 pontiac trans am gta
Transmission: t5
Axle/Gears: 373
Am I going to need dual coil valve springs for 488 comp cam part number 08_501_8 or can I just buy new single coil springs to prevent modifying the heads for the dual coil valve springs ?
Posted from Thirdgen.org App for Android
Old Jul 20, 2012 | 07:01 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: bigger dual valve springs for 488 cam ?
You could spend an extra $100 and go with beehive springs if you wanted. Maybe even these LS2/LS3/LS6 springs:
http://www.summitracing.com/parts/NAL-12499224/
Will require some cleverness and attention to detail to get the installed height and spring pressures balanced but it's more than doable.
Old Jul 21, 2012 | 07:37 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
you could just get some upgraded springs, i don't think you would need double wound springs
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
