how to remove this belt?? the smaller belt behind alt..
Old Jul 26, 2012 | 01:41 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
how do i remove the skinny belt behind the alt belt?? i can get the bigger off but i donot see how to losen the 2nd one to replace it??
thnx
Old Jul 26, 2012 | 02:13 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Re: how to remove this belt?? the smaller belt behind alt..
Forgot to add pic... it will be up soon
Old Jul 26, 2012 | 02:34 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
pics
Attached Thumbnails how to remove this belt?? the smaller belt behind alt..-belts.jpg   how to remove this belt?? the smaller belt behind alt..-2012-07-26_14-11
Old Jul 26, 2012 | 02:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
are you asking about your air pump belt ?
Old Jul 26, 2012 | 02:42 PM
Engine: Lb9
Transmission: M20
if so lay on the ground I think there is a threw pivot bolt and then a 9/16 or maybe 15mm tensioner bolt that need to get loosened.
Old Jul 26, 2012 | 02:57 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
the skinny belt behind the belt thats drives the alt
Old Jul 26, 2012 | 03:52 PM
Engine: Lb9
Transmission: M20
sorry it looks like you air pump is gone so you mist be dealing with your a/c or power steering ?
Old Jul 26, 2012 | 04:56 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
dont see an airpump, just alt, pwr steering and pulleys...
Old Jul 26, 2012 | 06:03 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, ill go try those bolts
Old Jul 26, 2012 | 06:55 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
my car doesnt have ac i think so is this why im missing the compressor/pump??
Old Jul 26, 2012 | 07:35 PM
Engine: Lb9
Transmission: M20
3,5,and 7 for the power steering pump
Old Jul 28, 2012 | 08:25 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
thnx for the help, i losened the large bracket the holds the pwr steering pump and pully together and was able to remove the belt, however, after days of trying i tried the new belt and pepboys sold me the wrong one! oh well, it was a good learning experience...
Old Jul 28, 2012 | 10:20 AM
Engine: Lb9
Transmission: M20
Hope Those pictures made it easier
Old Jul 28, 2012 | 07:39 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yes they did, thnx again...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
