Changing gas tank filler neck
Old Aug 2, 2012 | 01:08 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
I was wondering when your changing out your filler neck and gas tank how your suppose to attach the filler neck to the tank itself? I have a really clean used tank then a new filler neck but I didnt know if for some odd reason it was welded or if I can track down a rubber grommet or something that would hold it in?
Old Aug 2, 2012 | 01:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Changing gas tank filler neck
They get soldered on. If you don't have a monster size soldering iron can take it to a radiator shop to have it done.
RBob.
Old Aug 18, 2012 | 06:29 PM
Car: 1984 Trans Am
Axle/Gears: Stock
Im surprised no one has tried to use a rubber grommet to seat it. I have no idea since the shop ripped the old tank out and cut the filler neck what position to solder on the filler neck at. I have a new neck and a oem tank that I ordered. Maybe a 93+ firebird grommet?
Old Aug 19, 2012 | 04:04 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
RBob.
The correct and only way to do it.
Or you can return the tank and filler neck and buy a tank with the neck already attached.
Old Sep 8, 2012 | 12:16 PM
Car: 1984 Trans Am
Axle/Gears: Stock
Come to find out there is a grommet that works perfectly with the 82-92 firebird. Extremely tight seal and you need to lube it/heat it since its so tight but works perfectly, no leaks. If anyone runs into this and wants to switch to a grommet its the Dorman 577-500. 2.5 in od and 1.6 in id.
Old Sep 8, 2012 | 01:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Since the neck is almost a pressfit, that I gotta see! You have pix of it installed??
Old Sep 8, 2012 | 01:11 PM
Car: 1984 Trans Am
Axle/Gears: Stock
I can snap some, i took it apart while i finish undercoating it. The thickness of the actually grommet where it snugs into the lip is so small that it managed to work. I was amazed as well due to the normal minimal lip on these cars.
Old Oct 9, 2012 | 12:53 AM
Car: 1984 Trans Am
Axle/Gears: Stock
UPDATE:
Got the car done and took it on (2) 240 mile round trips with no problems. Gas neck is from spectra and actually seats right behind the gas door. So everything worked out well using the grommet and saves a bit of labor.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
