what size piston rings do i need
Old Aug 2, 2012 | 08:31 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i ordered a re ring kit from kmj preformance this week and i got it today and well my piston rings wont fit, they are too thick so what size do i need for my 96 block? im running stock pistons and the piston rings were suppost to be STD.
Old Aug 2, 2012 | 11:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: what size piston rings do i need
Are the rings metric?
http://www.ls1lt1.com/forum/lt1-|-lt...ring-size.html
http://www.camaroz28.com/forums/lt1-...0/#post2550183
STD relates to the bore size ; not the ring thickness
LT1 metric rings are different to old skool SBC imperial sizes
http://www.nastyz28.com/forum/showpo...20&postcount=2
Old Aug 3, 2012 | 07:54 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Metric rings. These are the ones I got for my 98 block
http://www.summitracing.com/parts/CLE-41858CP
You need to have a 400 grit de-glazing for these rings as they are plasma moly.
Old Aug 3, 2012 | 08:37 AM
1gary's Avatar
Don't get low tension rings and make sure you check the end gaps for the intended use.
This is a example from I-Con pistons:
Old Aug 3, 2012 | 08:39 AM
Engine: L31 350
I'll look at the box later, I know they are mahle steel rings and I thought they would fit my 96 vortec :/
Old Aug 3, 2012 | 01:32 PM
Engine: L31 350
i just ordered these, can you give me more info on the deglazing? this is my first engine build.
Old Aug 6, 2012 | 07:54 AM
LilSki's Avatar
Car: 85 Trans Am
Often called honing it is when you use one of those honing tools that has 3 spring loaded stones that you attached to a drill. While you spin the drill you move it in and out of the cylinder bore. All while lubricating with a light machine oil or WD-40. You only want to do it for a short period of time to take off the glaze on the cylinder wall. If you don't get the glaze off the cylinder walls the rings will never seat in correctly and it will be down on compression and probably burn oil.
For the plasma moly rings you want to use a 400 grit stone compared to the old school 220 grit
Old Aug 6, 2012 | 10:08 AM
1gary's Avatar
Well from what I read so far from you,your better off taking it to a machine shop and let them tell you what you need letting them hone the block.You do need to know how to get a good cross hatch on the cylinders and that takes experience.Not a knock against you at all,but for the time and money,it is well worth paying them to do it on a machine which will give you better results than with a hand hone.Maybe even have them do it with deck plates which represent what the bores are like once the heads are torqued on.We add .005 to the ring gap to prevent the ring ends from butting against each other.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
m00n420
Sep 11, 2015 02:39 PM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
