LT4 Hot Cam - LT4 or LS6 Springs?
Old Aug 5, 2012 | 09:51 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
I plan on installing the LT4 Hot Cam. The heads are GM vortec, already machined and installed with screw in studs.
Current springs are unknown and were originally installed in special ZZ5 vortec heads from Pace Parts bought on cleareance. I broke one of the studs and bent a push rod, for no apparent reason, after the heads installed. Engine runs rough but ok. Want to eliminate the springs as the engine issue.
LT4 are cheaper, $39, but the LS6 are also fairly cheap, but I need to use the Comp Cams 787-16 keepers.
Any ideas?
Old Aug 7, 2012 | 12:12 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: LT4 Hot Cam - LT4 or LS6 Springs?
LT4 springs are adequate for the LT4 production cam, but not for the LT4 Hotcam.
I can't speak for the LS6 springs.
Old Aug 7, 2012 | 12:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Find the reason behind the bent Pushrod and broken studs! Things just dont happen like that without reason. Those heads clearanced for the lift? Springs bottoming out?
Ls6 may work but 918 beehives would be better
deracer
Apr 11, 2016 12:04 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
