hose between tpi runners??
Old Aug 6, 2012 | 06:50 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
is this a vacuum hose running between my runners on the drivers side??
i was changing my tstat and it was lying there, should i remove the top intake plenum and reconnect?? if so, where does it go?? thnx
Attached Thumbnails hose between tpi runners??-hose1.jpg   hose between tpi runners??-hose2.jpg   hose between tpi runners??-hose3.jpg
Old Aug 6, 2012 | 07:52 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: hose between tpi runners??
looks like a vacuum line to me, can't you see where it went? https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Aug 6, 2012 | 08:03 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
so tight under there, cant really see... ill try a small flashlight...
then try and reconnect...
Old Aug 6, 2012 | 08:58 PM
red rock's Avatar
Car: 1987 iroc
I know I had some bad vacuum leaks under my plenum, lines & runner bolts. They should go towards the rear of the plenum. The EGR has a line to it.
Old Aug 7, 2012 | 12:16 AM
newagereject's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
There is a splitter back by the fire wall that two vacuum lines go to
Old Aug 7, 2012 | 05:06 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, so ill to connect it to the rear adapter or remove plenum and connect there? its the the largest hose so maybe it goes to the largest connection???
Old Aug 7, 2012 | 08:10 AM
red rock's Avatar
Car: 1987 iroc
You have to trace it back to what it"s connected to. Make sure it's not a windsheild washer pump hose or something like it.
Old Aug 7, 2012 | 01:41 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, never thought of that, i ll check wipers and squirters and make sure both sides spit....
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
