Mechanical fuel pump help
Old Aug 9, 2012 | 06:36 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
ok, so I know how to install it, or atleast I thought I did, the problem I'm having is, it's like the fuel push rod is not going high/far enough into the block for me to put the pump all the way to the plate.
A little background, I just swapped in a 350 to replace my 305. But I just swapped over my intake and my q-jet carb. the 350 is from a 78 C-10 that was also had a q-jet. It had a manual choke but I didn't think that would matter.
If anyone can help, I'd sure appreciate it, as I would like to drive this car after it's been sittin for a week now. THANK YOU!!!
Old Aug 9, 2012 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Mechanical fuel pump help
Try bumping the motor over.
JamesC
Old Aug 9, 2012 | 08:33 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Spin the motor a little and grease up the rod before pushing it into the block, this should help keep it up out of the way when you install fuel pump.
Old Aug 9, 2012 | 06:18 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
I got it in, thanks guys.
Old Aug 10, 2012 | 08:04 PM
B84's Avatar
B84
Car: 1984 Camaro Berlinetta
Engine: LG4 Ohv V8
Edward, I'm having the same issue but cannot locate where to spin the motor. Where/how would I do that?
Old Aug 10, 2012 | 08:08 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
use a long handled breaker bar or wrench using a 5/8 on the center bolt in where the belt pulley is at the bottom of the front of the motor
Old Aug 11, 2012 | 07:22 AM
Edwardgp's Avatar
Engine: 454-350
B84 what cowboy posted is a good way to do it. If you don't have all the tools you can quickly hit the key until she rolls a little.
Old Aug 11, 2012 | 01:24 PM
B84's Avatar
B84
Engine: LG4 Ohv V8
Thanks guys. I ended up taking the spacer plate off of the block and let the rod fall down, out of the block. I figured I might as well check the rod to make sure it wasn't beant. All put back together now and no leaks. Thanks for the help.
Old Aug 11, 2012 | 05:17 PM
Edwardgp's Avatar
Engine: 454-350
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
