General Question
Old Aug 27, 2012 | 09:55 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
General Question
I've had a 91 Camaro for over 10 years sitting in my parents garage and I finally have the room and $$ to get this thing where I want it. It currently has a 305, but I want to start the process to put a 383 stroker. Does anyone know of a good guide to make sure I am doing it right? I have a Haynes manual but I want something to help guide me with the right upgrades and what not so I don't do anything wrong! Let me know!!
Old Aug 28, 2012 | 07:05 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: General Question
Welcome ericeickhoff to third gen. I have never done a 383 but a lot of people on here have.
Old Aug 28, 2012 | 07:20 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Changing the engine to a 383 is very easy to due. Getting a good builder is going to be the most complex issue. Look through all the different area's on TGO and ask alot of questions. I used to have a 383 and impressed but got the need for speed just a little bit more.
Old Aug 28, 2012 | 07:29 AM
1gary's Avatar
What is your budget??. A lead-in good donor engine is a truck 1996 to 2000 roller block.
Don't think your going to build a class stroker bottom end and then cheap out on the heads/cam. If your budget is going to lead you in that direction,you best bet is to build a 355 saving the money not spent on the stroker and invest it in heads/cam for the 355.
Make no doubt about it. The power in made in the heads/cam in sbc/bbc's.
Old Aug 28, 2012 | 08:32 AM
1gary's Avatar
BTW:your parts list is a example of a build done right.Nice,very nice.
Old Aug 29, 2012 | 07:03 AM
ibmtech's Avatar
Car: 1987 IROC-Z
thank you. I can't take the credit for building it though. I just paid out the a$$ to have it built for me.
Old Aug 29, 2012 | 07:37 AM
Edwardgp's Avatar
Engine: 454-350
Well let us know how she performs, hopefully you will get it to hook up.
Old Aug 29, 2012 | 08:36 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Im considering a 383 as well. Im keeping the tpi setup, plan on using the lt4 hotcam, undecided on heads, but since im planning on being done at ~5500-6k rpms i want all the low-mid range power i can get. I think a 383 would be a great idea for this. I dont plan on building the engine though, if im able to buy one then just put the cam heads and intake on it I will do that. But I dont want to go any further than that.
I found a nice 383, problem is its roughly $2k to buy:
http://www.rebuilt-auto-engines.com/...22111123734.82
Anyone know of any like this but cheaper? Or is it cheaper to get my 350 rebuilt to a 383 and how i want it?
Americanmouse
Sep 7, 2015 12:10 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thaney9
Aug 29, 2015 03:16 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
