fixed heater core. now won't blow out ac vent
Old Sep 6, 2012 | 03:06 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So after i fixed the heater core. My ac will blow down by the passenger feet area. It will not blow out the normal ac vent. I have the cover for the heater core currently off. But even when i put the cover back on the heater core it now blocks the ac from coming out the feet area. What gives. Im i blocking the door for the ac vent. Need help fast. It hot outside.
Old Sep 6, 2012 | 07:13 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: fixed heater core. now won't blow out ac vent
You might have knocked a vacuum line off one of the actuator diaphrams when you were under the dash.
Old Sep 6, 2012 | 08:46 PM
Car: 91 formula
Damn. That sounds like a needle in a hay stack to find.
Old Sep 6, 2012 | 09:45 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Not really, there are only approximately 4 possibilities.
Old Sep 6, 2012 | 10:03 PM
Car: 91 formula
alright. I will take a look and let you know. Thanks.
Old Sep 6, 2012 | 11:07 PM
Car: 91 formula
alright so I narrowed it down to what the problem is. Its the vent doors. I held the vent door that is on the inside of the dash open with some wire and it blew out the vents out to the interior. But when I throw the lever to make it blow on the windshied it still comes out the same vent facing the interior. So its in the lever and vent doors behind the dash. Any ideas.
Old Sep 6, 2012 | 11:18 PM
Car: 91 formula
I read that 90-92 cars use vacuum operated ac doors. Maybe I hit something underthere. Anyone have a diaphram of this. Any help is greatly appreciated.
Old Sep 7, 2012 | 12:19 AM
Car: 91 formula
anyone know where this vacuum line plugs into.
Attached Thumbnails fixed heater core. now won't blow out ac vent-heater-core-vacuum-problem
Old Sep 7, 2012 | 07:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The elbow plugs into a hard plastic vac line that goes into the inside of the car to run the HVAC doors.
Those little rubber lines need 2 be replaced.
Todd84Z
Sep 4, 2015 08:02 AM
WIzmo
Aug 30, 2015 02:30 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
