LT1 cam
Old Sep 8, 2012 | 09:48 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
LT1 cam
Will an LT1 Cam out of a 95' Z28 work in my 87' L98??? Please excuse the rookie question...lol
Old Sep 8, 2012 | 10:08 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: LT1 cam
it will if the 87 block has a roller cam in it.
Old Sep 8, 2012 | 10:22 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: LT1 cam
Ok thanks!...Is there a noticeable difference in performance???
Old Sep 8, 2012 | 10:25 PM
Engine: L31 350
Re: LT1 cam
not sure, havent started my new motor yet to be able to tell you!! lol. im sure it will be though.
Old Sep 8, 2012 | 10:28 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: LT1 cam
87+ is a roller block.
Yes an LT1 cam will fit. Don't know why you'd bother unless someone gave you it for free.
Old Sep 8, 2012 | 11:42 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: LT1 cam
Not much of a difference? I'm not looking for anything too crazy but I would like a nice jump in power. What kind of cam would you recommend?
Old Sep 9, 2012 | 08:05 AM
Re: LT1 cam
There are several "LT1" cams; the one in the B body motors is not much different from the one you already have. Some of the ones in F and X bodies are slightly more aggressive (emphsasis on "slightly") but I can't recall exactly which ones. All in all though, ALOT of maze to run, in exchange for VERY LITTLE cheeeeeze at the end. Even free, I wouldn't bother.
For an otherwise mostly stock L98, this one http://www.summitracing.com/parts/CCA-08-502-8/ is a pretty good choice.
You WILL need to upgrade the valve springs.
Old Sep 9, 2012 | 08:25 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: LT1 cam
That one Sofa chose will require custom tuning.
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: LT1 cam
Ok thanks..I will have the lower intake, plenum and runners all ported and will be putting some Dyno Don headers on as well...any particular brand or kind of valve springs I should look into??
Old Sep 9, 2012 | 08:51 AM
Re: LT1 cam
Whatever the cam mfr recommends.
In the absence of that, I'd suggest their (Comp) 986 springs along with all the hardware that goes with them (machine work will be required), and a set of their steel-body (NOT aluminum) roller-trunnion rockers.
Old Sep 9, 2012 | 09:37 AM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: LT1 cam
Hey thanks for your help Sofakingdom! I appreciate your input! I am looking into all of these parts.
Old Sep 9, 2012 | 07:50 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: LT1 cam
Custom tuning???
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
