what is this sound
Old Sep 16, 2012 | 12:16 PM
wrc's Avatar
wrc
what is this sound
hello all , this is my 1st time posting. this site has alot of great information. I was wondering if anyone had a clue what this sound is.
I have a 91 rs 305 all stock.
http://www.bornofhades.com/songs/car2.mp3
The sound file I turned up during recording the sound is al the same volume all the time.
any help would be greatly appreciated!!!!!
Old Sep 16, 2012 | 10:31 PM
wrc's Avatar
wrc
Re: what is this sound
mmm is my sound file working for all, or is the sound that odd???
Old Sep 17, 2012 | 07:16 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
File not found bro.
Old Sep 17, 2012 | 08:41 AM
wrc's Avatar
wrc
thanks, the dam thing played for me.
please try this i embeded a player in a page, hope this works
http://www.bornofhades.com/1991_rs.htm
Old Sep 17, 2012 | 09:07 AM
Edwardgp's Avatar
Engine: 454-350
Yes that one worked, does the noise go away or not.
Old Sep 17, 2012 | 09:17 AM
wrc's Avatar
wrc
Edwardpg thx for thr reply,
the noise start when you 1st start it in the morn then does it a few time while driving then goes away, but once in a while it will appear again. also it very loud
Old Sep 17, 2012 | 12:30 PM
Edwardgp's Avatar
Engine: 454-350
Do you have an automatic or a manual transmission.
Old Sep 17, 2012 | 12:32 PM
wrc's Avatar
wrc
automatic
Old Sep 17, 2012 | 12:45 PM
Edwardgp's Avatar
Engine: 454-350
This could be the flex plate or inspection plate rubbing the flex plate. Might be something to look at. Is your starter OK.
Old Sep 17, 2012 | 12:48 PM
wrc's Avatar
wrc
iam unsure what a flex plate or inspection plate even is i will need to look that up... the starter is a new rebuilt one from napa... also had the same sound with the the other starter.
Old Sep 17, 2012 | 12:51 PM
wrc's Avatar
wrc
also the sound appears to be right around the air filter area
Old Sep 18, 2012 | 10:51 AM
wrc's Avatar
wrc
thx Edwardpg, i have read up on the flex plate and inspection plate def somthing to check. i will soon the car is dead in the water right now, dam VATS or starter solenoid flip a coin.
Old Sep 18, 2012 | 11:00 AM
Edwardgp's Avatar
Engine: 454-350
Keep us up to date maybe we can help you out if you can't find the problem.
Old Sep 18, 2012 | 11:10 AM
wrc's Avatar
wrc
ok i will thx very much!!!!!
Old Sep 18, 2012 | 01:51 PM
slackett66's Avatar
Could it be an accessory pully? Sounds like it to me.
Old Sep 18, 2012 | 02:12 PM
wrc's Avatar
wrc
slackett66 thx for the reply i do think i have a pully going band just unsure what one yet. when i was recording the sound i heard it right around the air fliter, its a very odd thing well to me... but for sure worth a check!
Old Sep 18, 2012 | 09:53 PM
slackett66's Avatar
Turn it off....
Pull the Serpentine belt. (Make sure you know its routing and can reinstall.....)
Check the Idler/Tensioner pully... Those have been know to go bad and seize up. Spin it/rattle it...whatever...heck, try all the pullys.
If you feel any 'side play' hear rattles, grinding. Could be your culprit.
Old Sep 19, 2012 | 09:48 AM
wrc's Avatar
wrc
slackett66 thx added to my weekend list
Old Sep 25, 2012 | 12:06 PM
wrc's Avatar
wrc
ok i went thru the list and no luck still have the dam odd sound, i believe it could be the Distributor the sound is appears to be coming from it, that will be next on the list. dose anyone know if a Distributor
can even make a sound like that???? maybe grabing at straws
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
