CAR IS REALLY MISSING BAD
Old Sep 28, 2012 | 09:13 AM
firebird's Avatar
Guys,
I've got a 1988 GTA , 5.0. Last week I took it in for a tune-up because the car was bogging down just a little upon take off, but wasn't that big of a deal. The shop replaced all of the normal stuff (plugs, plugs wires, fuel filter etc,). When I picked the car up I noticed a slight miss at idle, but otherwise the car ran fine for about 3 days, then it began to miss a little more at idle, then totally just wouldn't run at all. The idle is bad, and when I put it in gear to drive, it will pop and pop like it's receceiving no fuel or fire to the plugs at all. I'm at a loss, and my mechanic is trying to troubleshoot. So far we've replaced to 02 Sensor, which help some, but didn't correct the problem totally. We also replace the air intake gasket, which was broken, but no real change. We also check the fuel pressure, and it's okay too. Now we're thinking that it has to be electrical, and there's a short somewhere. Can anyone hear shed any light on this experience?
Thanks,
Jeff
Old Sep 28, 2012 | 09:39 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: CAR IS REALLY MISSING BAD
If it wasn't missing prior to the tune up then the first place that I would start is by taking a look at the work that has been done. Check the plugs or plug wires and whatever else was done for the tune up. It could be unrelated and just a coinsidence but this is probably the easiest place to start.
Old Sep 28, 2012 | 10:05 AM
firebird's Avatar
Thanks Chris C. At this point everything is suspect...
Old Oct 4, 2012 | 11:09 AM
firebird's Avatar
Re: CAR IS REALLY MISSING BAD MIFFED 88 GTA 5.0
So, I had to tune-up job re-checked by a different mechanic, and he too, found no issues with the tune-up. He suggested that I dig further because it's definitely missing. The fuel pressure and compression was check as well. We're thinking electrical. Can anyone give me some more ideas? Oh, I should mentioned that I recently had the engine bay steam cleaned, but didn't notice any difference other than the miss that was already there after the new tune-up, which progressively got worse over the next few days. I really need to run this to ground, so any help is appreciated.
Jeff
Old Oct 4, 2012 | 11:53 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
This. I'd see if I could narrow it down to just one cylinder that is missing. If so, then he's likely got a suspect plug wire, cap or rotor. I'd make sure no wires are touching anything hot like a manifold.
The steam cleaning could have damaged a sensor such as the TPS that could result in symptoms like the OP described.
Old Oct 7, 2012 | 01:11 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
check that your egr solenoid is holding vacuum. mine wasn't and was missing to the point that driving was awful. it caused everything else to look bad and a changing spree soon happened. i wouldn't have noticed it if i wasn't looking for broken wires during my cap/ rotor change. sure enough it wasn't holding vacuum and kept my egr valve open all the time.
Old Oct 7, 2012 | 01:19 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I want to add that you should check your injectors with an Ohm meter. Your symptoms also mimic bad injector(s). When they heat up, they tend to short out. One shorted injector will bring down the whole bank (side of the engine) making it shake horrendously. A bad one on each side will shut the whole thing down until it cools down.
Old Oct 9, 2012 | 09:02 AM
firebird's Avatar
Here's an update. As it turns out, I had 2 bad injectors. Replacing them both today, so hopefully that solves the problem. Thanks for all of your input.
Jeff
Old Oct 9, 2012 | 09:10 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Replace them all, it's the same amount of labor. Just costs a little more. The other injectors are all ticking time bombs, they will most assuredly fail. You can buy a whole set of rebuilt Bosch IIIs from someplace like southbay for less than $200.
hectre13
Dec 11, 2023 08:14 AM
86IROC112
Apr 9, 2016 10:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
