mechanical vs vacuum dizzy. MPG difference?
Old Oct 2, 2012 | 04:32 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I currently have a mechanical distributor in my car that I got for free. I've heard that a vacuum advance will get better MPG's. I get about 15 city driving right now so how much of a difference would vacuum advance really make?
Old Oct 2, 2012 | 08:52 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: mechanical vs vacuum dizzy. MPG difference?
Tough to give an exact number but 3 MPG might be a safe number to throw out there. Could possibly go as high as 5 MPG. The reason it makes a difference is the extra advance allows you to cruise with less throttle therefore using less fuel.
Old Oct 2, 2012 | 09:33 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Don't have exact figures either, but I've run with vac off while dialling in the mech advance, difference in mpg was about 30%. Forgive my ignorance, but there are mech advance distributors that don't have the vac can?
Old Oct 2, 2012 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mechanical advance works strictly off distributor rpm. The weights and springs control how quickly the advance comes on and how far it advances. For best performance, timing should be at full advance by 3000 rpm.
Vacuum advance is for part throttle operation. As the engine load changes, the vacuum advance advances or retards the timing strictly based on the intake manifold vacuum signal from the engine load. At WOT the vacuum signal is very low. At an idle or just off idle, the signal is high.
For a street car, you want a distributor with a vacuum advance because you're driving it at part throttle most of the time. For the dragstrip, vacuum advance is an unknown variable. Mechanical advance only or a locked out distributor works better.
Old Oct 3, 2012 | 12:00 PM
Gsoleski's Avatar
Car: 1984 Z28
Awesome thanks guys. Looks like that's in the next paycheck. Would this help with highway mileage too? Or is highway not really part throttle
Old Oct 3, 2012 | 12:17 PM
LilSki's Avatar
Car: 85 Trans Am
It should help with any kind of driving except for WOT. It will be not different than mechanical only at that point as there is little to no vacuum.
Old Oct 3, 2012 | 01:02 PM
ex-x-fire's Avatar
Hey gsoleski, is this on your 84 z28? That should be a computer controlled distributor, all advance is handled by the ecm. I think the dist. helps the ecm run the feed back carb.
Old Oct 3, 2012 | 01:19 PM
Gsoleski's Avatar
Car: 1984 Z28
sorry forgot to mention that. The computer is long gone
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
