Will this sending unit work with my car?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my 84 z28, its got an LG4 engine in it and my sending unit is gone out since they gas gauge is not accurate and im sure the gauge is not broken...I got a mechanical fuel pump but was wondering if this would fit my gas tank?seems pretty simple that's why I liked it?and could I also just wire this to an aftermarket fuel gauge?thanks!
or any other suggestion for sending units??thanks again!
http://www.jegs.com/i/Rick%26%23039%...SU090/10002/-1
Re: Will this sending unit work with my car?
Is there some reason you would not just buy a stock replacement? I mean, the gague and sender are calibrated to the same spec (and guaranteed to fit) so...... what's the problem with that?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i think most (or all)GM from~1965 to around late-80s all used the same resistor unit on the sender-if your resistor is bad,you could probably salvage a good resistor from about any GM sender from the era mentiond-i used resistor from '83 impala sender to fix '68 chevy pickup sender-looked and worked exactly the same
just had to bend some tabs or something to switch out.Could check the full VS empty ohms of the sender to be sure it is bad before dropping tank.
just had to bend some tabs or something to switch out.Could check the full VS empty ohms of the sender to be sure it is bad before dropping tank. Thread Starter
Car: 1984 Z28
well Ima just end up making a cut on the top of my tank to get to the unit (easier) but for this sender dont i just need to match it with a gauge that has the same ohms?but im still not sure if itll fit though?
Car: 1984 Z28
I was also looking at something like this:
http://www.summitracing.com/parts/RSD-YSU6901/?rtype=10
anyone know how come the first one looks a lot simpler than this one?
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
The first one only looks simpler, until you have to cut a new hole in your gas tank to mount it. The second one you showed looks allot more like the thing the factory used. The sending unit is permanently attached to the pickup assembly. The fuel pump mounts onto this too. The original GM pickup assembly cost over $400 from a dealership back in 2000. Rockauto should have the exact part you need.
Car: 1984 Z28
alright thanks for the help........I appreciate it........ima look into it.
Ghettobird52
Jul 5, 2024 11:18 PM
hectre13
Dec 11, 2023 08:14 AM
