No Start Again
Old Oct 11, 2012 | 03:55 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
No Start Again
Someone PLEASE help. 1987 GTA with 61000 original miles.I have replaced the plugs,wires,cap,rotor,coil,fuel pump relay,and now the fuel pressure regulator.....AND STILL NO START.....WTF. Right after I replaced the fpr it started and ran fine THAT evening and now no start.WHAT CAN POSSIBLY BE WRONG WITH THIS CAR.
Old Oct 11, 2012 | 04:53 PM
AvantiHall's Avatar
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
Re: No Start Again
Can't keep throwing parts at it. First, does it gave spark, unplug a plug wire, rig it to gap 1/4 inch. Have someone crank and watch for spark, and how hot it looks. If no spark stop. If spark pull 1 spark plug, is it wet, smell like gas? Compression test? Let me know, we need to find out which way to go!
Old Oct 11, 2012 | 05:17 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
It has spark,and when it feels like it.........it starts and runs fine.But now after fixing what it was diagnosed to need,it will not do anything but crank
Old Oct 11, 2012 | 05:20 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
This car is in excellent original condition and has very few miles on it, it has been drivin a total of 1500 miles since 1999 if that has anything to do with it
Old Oct 11, 2012 | 05:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No Start Again
Back to basics.
Need to find out what you are missing
Fuel or spark ???????
we need to know before we can help further
Old Oct 11, 2012 | 07:49 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
Its getting both and this car ran excellent when i bought it several months ago and now wont start all the sudden....took it to a garage to get a diagnosis as another opinion and they said it was the fuel pressure regulator.I replaced it and still nothing.I dont want to fix anymore stuff and waste money.Could the fuel pump be another culprit
Old Oct 11, 2012 | 08:47 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: No Start Again
Originally Posted by GTA387
Its getting both
How do you know?
What is the fuel pressure at the rail ?
Does it hold constant?
Are the injectors being pulsed?
As noted above , are the plugs wet with fuel?
Just because the pump is pumping doesn't mean fuel is getting into the engine ( or in right amount)
Old Oct 11, 2012 | 08:56 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
Im not anything more than a basic mechanic......My local garage looked at it and told me it was the fuel pressure regulator but wanted 500 bucks to fix it. I did it myself because thats too much.Now i cant get it started to get it looked at again and i have just basic tools brother so im at a loss
Old Oct 12, 2012 | 11:29 AM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
Re: No Start Again
Take a trip to a parts store and rent or purchase a fuel pressure gauge. It is simple to hook up to the fuel rail if you trace the fuel pressure regulator back you will see a black cap unscrew it and attach the gauge. turn the key to start and check the numbers. should be around 42psi
i would also check that you did not disrupt the ignition coil or module connections while you changed the regulator
Old Oct 14, 2012 | 03:29 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
I have not tried to start this car for a COUPLE of days and just now i tried it and it started right up..............????????????????
Old Oct 14, 2012 | 03:30 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
i will try the pressure gauge and post results .....thanx
Old Oct 16, 2012 | 07:48 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Re: No Start Again
The car now started and drove very well and then after a 30 minute drive, I shut it off for a bit,went to start it and now as soon as it settles down to normal idle ..... it stalls out
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
