What sparkplugs to use?
Old Oct 28, 2012 | 08:03 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Im having a hard time figuring out what specific spark plug to run on my Firebird
I am confused about heat ranges, and i figure some of you would probably know.
Specs:
Chevy 357, 10.65:1 Compression, 520/544 lift cam 310 duration, 2.02/1.60 Procompelectronics heads 64cc. Stock rods & crank
What the cyl head company says:
Spark Plugs
All Procomp 23deg. SBC heads use standard 14mm. x 750' reach, 5/8 hex, gasket seat sparkplugs like NGK R5671A-7, Autolite 3924, Champion RC12YC, etc.
Remember that higher compression/ boost require a colder heat range sparkplug.
Any ideas guys?
Old Oct 29, 2012 | 07:24 PM
Re: What sparkplugs to use?
AC/Delco R43TS
Old Feb 21, 2013 | 06:41 PM
krackle82's Avatar
I've been looking into this lately. I found that AC Delco offers 3 plugs that are 14mm .750 reach 5/8 hex. c43ts, c44ts and c45ts. R= resistor plug 4= 14mm thread 3,4,5 =heat range TS= Tapered seat. Cold engines (low compression) need hot plugs and Hot engines (high compression) need cold plugs. If you want to stay with AC Delco, go with the c45ts. Its the coldest plug you can get in that brand at Autozone, O'Rileys, ect.
http://aftermarket.federalmogul.com/...ce%20Chart.pdf
Infested
May 22, 2018 11:56 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
pm_
Oct 16, 2002 12:33 PM
Mike86Z28
May 27, 2002 05:57 PM
WaynesRS
Feb 12, 2002 01:06 PM
