91 Camaro RS Distributor Mystery *HELP PLEASE*
Car: 1989 Pontiac Firebird Formula
Engine: 327 sbc
Transmission: 400 turbo with Shift Kit
I'll just get to the point. Car won't start. I am getting spark to the to the ignition coil when my engine turns over but doesn't fire. I replaced my coil and cap and wires. But yesterday I took out my spark plugs and I am not getting spark to the Spark Plugs. I am getting fuel and air, just no spark. I bypassed vats also. This holding my project back. I don't want to give in and just get an aftermarket setup because saving money is key for me. So any info will help
and I always get good feedback from ThirdGen. Joined: Dec 2004
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 Camaro RS Distributor Mystery *HELP PLEASE*
how are you checking for spark a 4okv tester ?
Engine: 327 sbc
Volt meter and looking for a spark with the plug out of the block but hooked up to the distributor.
Car: 91 camaro rs v8
Engine: 305,5.0 liter
Axle/Gears: 10 bolt 355
replace ur igntion module its under your distributer cap and has to electrical connections form the side of it ,costs about forty dollars and change easy install
Engine: 327 sbc
I went to get it tested and it past. I'm actually working on it now. I'm out of ideas
