Swapping out distributor... what are my options out there.??
Old Nov 26, 2012 | 06:05 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my 84z28 I opened up my distributor and when I did the inside of it looked kind of burnt and pieces of the inside plastic literally fell off.....and I was wondering why my car ran rough..LOL....so far its still running with this distributor but was wondering what are my option out there...?
I got a 84 z28 with an LG4 engine....not looking to spend $300 on a new one budget is $150 tops....thanks!
Old Nov 26, 2012 | 07:48 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Swapping out distributor... what are my options out there.??
If the distributor is in good shape mechanically, I'd just replace the cap and rotor with ones from a parts house and run it till the cows come home. Will probably run you under $30.00 at some place like Autozone.
Old Nov 26, 2012 | 08:17 PM
calgutie's Avatar
Car: 1984 Z28
well i think its good mechanically speaking since the car is running....but I was thinking of getting one of Jegs distributors since they got em on special for $100...what do you think??would it work with my car?
Old Nov 26, 2012 | 08:36 PM
jtsk's Avatar
Jeg's sells some good stuff, so yeah, it should work ok. I replaced my whole distributor in my 92 z28 with one from O'Reilly's Auto Parts. It was a complete unit, plug and play for $139.00. Granted it was a stock replacement, but I have had no issues at all with it.
Old Nov 26, 2012 | 08:43 PM
calgutie's Avatar
Car: 1984 Z28
I see I was thinking of either getting something like this which is cheaper...
http://www.jegs.com/i/JEGS+Performan...40400/10002/-1
or this
http://www.jegs.com/i/JEGS+Performan...40005/10002/-1
this one is plug in play right? and u think its better than my stock one..?will it make a difference power/driving wise?
Old Nov 26, 2012 | 08:51 PM
jtsk's Avatar
Is your car still controlled by the computer? If so, this distributor wont work as it is vacuum controlled on the advance. It will work fine if your car isn't computer controlled anymore. As for power, not really. Power is going to come from the heads and cam, and a good distributor will light it all off and deliver a good strong spark. Until you mod up your engine, you wont notice much of a difference, but you should get better mileage at least.
Old Nov 26, 2012 | 08:52 PM
calgutie's Avatar
Car: 1984 Z28
I beleive it is computer controller becuase i have a computer controlled quadrajet carburator but as for my stock distributor it doesn not have the vaccum advance on it....so what would work then??
Old Nov 26, 2012 | 08:57 PM
jtsk's Avatar
You would have to replace it with a distributor for a computer controlled car. Jeg's may sell one, I'm not sure. You might have to go to a local parts house to find one. Honestly, I'd just replace the cap and rotor and ignition module and let it rip until you are ready to mod it up. That would be your cheapest route.
Old Nov 26, 2012 | 09:00 PM
calgutie's Avatar
Car: 1984 Z28
alright well thanks for the great info....but you think for the time being i could just go with that $25 one...?
Old Nov 26, 2012 | 09:02 PM
jtsk's Avatar
sure, that was just a cap and rotor and at the least you need to replace that.
Old Nov 26, 2012 | 09:05 PM
calgutie's Avatar
Car: 1984 Z28
ye I would want to replace it because when i took mine apart.....and that think literally looked like burnt toast in the inside..LOL..
Old Nov 26, 2012 | 09:07 PM
jtsk's Avatar
I'd go ahead and change the ignition module while you got it apart also. It surely won't hurt.
Old Nov 26, 2012 | 09:10 PM
calgutie's Avatar
Car: 1984 Z28
dont mean to sound dum but whats that part..
Old Nov 26, 2012 | 09:14 PM
jtsk's Avatar
that is the "brain" of the distributor so to speak. it's located inside the cap under the plate. 2 screws hold it in. Yours is working or the car wouldn't start, but since you are changing everything else, you might as well change it too.
Old Nov 26, 2012 | 10:30 PM
calgutie's Avatar
Car: 1984 Z28
ahhh i get you know....now I knwo what you are talking bout...are those expensive?
Old Nov 26, 2012 | 11:10 PM
jtsk's Avatar
$30 or less at Autozone.
Old Nov 26, 2012 | 11:11 PM
calgutie's Avatar
Car: 1984 Z28
not bad ima look into it...thanks!!
Old Nov 26, 2012 | 11:15 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
There isn't really any point to replace the ICM if it's working. There will be no benefit and maybe even a loss of reliability if you replace the GM ICM with a cheap aftermarket one.
That said, as long as you're in the distributor I think it would be a good idea to remove the ICM, clean off the back of it and the area in the distributor where it mounts, then reapply new/fresh heat sink grease.
Old Nov 26, 2012 | 11:16 PM
calgutie's Avatar
Car: 1984 Z28
alright great....ima do this all on the weekednd when i got more time...thanks 4 the info..
Old Nov 27, 2012 | 05:30 PM
calgutie's Avatar
Car: 1984 Z28
hey you guys so i talked with summit and on theri site the only computer controlled distributoir they have is thei re manufactured one and it doesnt include the cap or coil...and they also have another one by accel but its around $250 for it.....anythign else out there? and is there anyway i can hook up one of those $100 summit non coputer cottrolled distributors to my car or is it too much of a hassle..?thanks.
Jorlain
Aug 24, 2022 05:11 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Sep 2, 2020 07:13 PM
RedLeader289
Jan 22, 2016 03:05 PM
InfinityShade
Aug 22, 2015 08:00 PM
