Metal tinging noise coming from front of motor? (SOLVED)
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
So over the last several days I have noticed this sound originating from the front of my motor. This noise started off faint but has now become a constant noise.
It sounds as if a bracket or something metal is bouncing into a pulley, but there is nothing flopping around down there that would be an obvious cause to this noise...
I had the TPS sensor unplugged when I filmed the video so the rpms would be up and the noise would be noticeable.. At idle the noise doesn't occur anywhere near like it does when driving.
http://s58.beta.photobucket.com/user...ba5b6.mp4.html
Any ideas?
Any ideas?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Metal tinging noise coming from front of motor? (VIDEO)
sounds strongest around the pulley area-try running it with the belts off and see if you get the noise...
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Really sounds like one of those pulley bearings is bad, I would guess water pump.
Car: 87' GTA
Engine: 350 L98 TPI
I just had the water pump replaced with a brand new one less than 1k miles ago... I really hope it's not the crank pulley going out...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: 4++,350 & 305 CIs
To the.... sway bar or the to the hood....
Waaa waaa waaa
Could be any number of things. timing chain hitting the cover, balancer coming apart hitting the cover a loose anything from the waterpump swap.
As said before, pull belts one at a time and see if you can narrow it down.
Waaa waaa waaa
Engine: Lb9
Transmission: M20
Car: 87' GTA
Engine: 350 L98 TPI
Turns out the noise was being caused by the power steering pump belt. Considering I don't have a belt on my AC compressor (doesn't work ATM) I didn't pay close enough attention during my header swap, and put the power steering belt in the wrong grooves. (The belt was still straight, but just moved up a notch instead of where it originally sat) Once I put the belt back to where it was supposed to go and tightened it up, the noise went away.
theshackle
Sep 17, 2020 08:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
