starter doesnt always engauge into the flexplate?
Old Jan 5, 2013 | 11:57 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iv been having an issue the last few days with my starter not completely engauging with the flexplate when i go to start the car, i just did a new motor swap, including a new flexplate, starter, and i installed a new battery. it was after i installed the battery that i noticed the issue. when i go to start the car i can hear the starter engauge into the motor and try and crank it over, but then it will stop and just spin like it broke free of the starter, it will do this for a few more times before it will catch and start the car up. any advice?
Old Jan 6, 2013 | 12:06 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: starter doesnt always engauge into the flexplate?
probably a bad starter"bendix"
Old Jan 6, 2013 | 12:22 AM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Make sure the starter bolts havent came loose! Broken bolts can suck!
Old Jan 6, 2013 | 08:11 AM
Engine: L31 350
already checked those, they're fine
Old Jan 6, 2013 | 10:40 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Did you re-shim the starter? you need to add shims.
Old Jan 6, 2013 | 10:41 AM
ninetyone's Avatar
Axle/Gears: 3:42
Don't expect everything to fit exactly like it was before. Those tolerances are very strict. Changing anything down there can throw off things dramatically. You probably just need to add a shim now.
Old Jan 6, 2013 | 11:17 AM
tzim350HO's Avatar
Engine: 350 carbed
Save yourself the trouble and just have the starter checked by a good place. Sounds like the bendix is just kicking out on you.
Old Jan 6, 2013 | 11:21 AM
tzim350HO's Avatar
Engine: 350 carbed
If a starter is too close to the flywheel it will make an awful racket screeching, grinding, also the starter drive will get hung in the flywheel and that means add a shim or two. Too far away and they start kicking out, grinding, eventually tearing up a good flywheel!
Old Jan 6, 2013 | 01:03 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
This guy will show you what to do.
Old Jan 6, 2013 | 07:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
Yes , it could be the bendix not coming forward like it should.
Old Jan 6, 2013 | 07:26 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Is this a mini style starter? Mine had the same problem and it tore up my flywheel. Got it shimmed after I replaced the bendix and flywheel and it still tries to kick out every once in a while, they are junk in my opinion.
Old Jan 7, 2013 | 09:55 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Check the easy stuff first like others have suggested but also double check to make sure the flexplate is facing the correct direction. My father in law bought a 72 monte carlo last year with a 350/700-r4 that was swapped in by the previous owner and the starter would occasionally grind and sometimes not engage at all. I found the flexplate was installed backwards causing the starter to just barely engage the flexplate. Took the engine out and installed a new flexplate the correct direction and its been working great.
Old Jan 9, 2013 | 08:53 PM
dlinger's Avatar
Car: 1984 Z28 HO
Also check to make sure you have good grounds.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
