need help my fuel rails are flooding gas everywhere
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
I just turned my key to the position before on and my fuel pump kicks on like always, but this time there was gas just coming out of the little air looking valve thats in the back of the rails or runners whatever you call them, and they keep pouring gas out and wont stop, whats wrong> sorry for long sentence
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help my fuel rails are flooding gas everywhere
Schrader valve . Is the same as the valve that holds air in your tires
http://en.wikipedia.org/wiki/Schrader_valve
Remove the valve and install a replacement.May have to clean the valve seat , may be rust or cr*p there
preventing valve fom sealing
Must have a Viton seal to be fuel proof , not a reg valve as used for our tires
Local parts shop should have it
Car: 91 Z28 camaro
lol i just found the name of it on google and basicaly ur saying its just sticking open, and buy a new one rite?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If the fuel pressure test port isn't cracked around the outside, the "Air valve" need to be replace assuming no one has cross threaded it in, or used the wrong valve, and yes that's exactly what it is. just like the ones used for wheels and even the A/C system for freon charging. They are called Schrader valves.
Car: 91 Z28 camaro
the valves thread is fine, and its not cracked around the schrader valve im guessing the valve is sticking, or im getting to much fuel rite? Im just gonna go to o' rielys tommoro and get another one and it should fix it rite
Car: 88' IROCZ
Axle/Gears: 2.77
I don't think the stock fuel pump can over pressure the Schrader valve.
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
it will be very tiny , you only have to replace the inards , they should be able to supply you with a tool for easy removal /instalation.
Car: 91 Z28 camaro
what is the innards? My sister went t go see if they could match it at o'rielys with another valve, but what is the innards and how do you replace
Car: 82 Z28
Transmission: T400
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The band on a fuel used Schrader I believe is white the same as ones used in a/c systems.
