Heads upgrade help
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Heads upgrade help
I want to upgrade the heads in my 87 GTA and need to confirm the engine. I am new to this so will need a bit of details. I would like to know how to confirm the engine year and details so I can match the heads. How can I find the year whether it is 87 or older. I have found the engine number: 10054727. The intake number is 10066015, is that a stock intake?
Transmission: 4L80E/4L80E
That block is a 1-piece RMS 350. About all you need to know is that it's a 350 if you're upgrading the heads.
If you want to know what heads to get to match your intake, that's a little different story. I don't have intake casting number data at my fingertips, but if your current heads are cast iron and center bolt valve cover, then it's a safe bet they have the '87-up intake mount bolt pattern.
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: Heads upgrade help
Thanks tzim, I have headers on it already and 305 heads according to the numbers on them. I dont know about any other performance internal. It has aftermarket pulleys and an MSD coil.
I have a couple of heads I have been looking at, would you guys help to determine if it works. I plan to upgrade the cam also.
http://www.speedwaymotors.com/Dart-A...Plug,8775.html
Will these heads give me about 400 hp with a cam change?
Engine: 350 carbed
Looks like a nice choice to me! Im making 420hp but im running a cast iron head. Depending on what your wanting as far as a cam goes depends on alot of things! Is yours carbed or fuel injected?
The one in my profile: TPI, 350 with 305 heads.
Engine: 350 carbed
I know alot of people that seem to like the lt4 hot cam setup. Ive tried it but i had the305 58cc heads at the time and it absolutely killed it. performance sucked with those heads and a bigger cam. I gave up on it and carbed mine. Spent alot of money but itll flat fly like a bird now.
where do I get info for the LT4 hot cam?
Engine: 350 carbed
ambainb
Apr 25, 2016 09:21 PM
509 camaro fan
Sep 6, 2015 10:43 AM
NinjaNife
Aug 23, 2015 11:49 AM
