305 tpi to a 350 tpi swap
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
305 tpi to 350 tpi .my car is a 1985 tpi non roller but i want to use a 350 tpi roller . will the ecm know it has a roller cam or not. and can i just buy the chips for a 85 350 tpi and will it work . or do i need a87 to90 ecm.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 305 tpi to a 350 tpi swap
The 350 uses 21lb injectors. I'm not sure if the roller cam matters or not.
Engine: 4++,350 & 305 CIs
Tune the chip for 350, use correct 22lb injs and correct 350 knock sensor(if you want to plug it back in). Try to get a good exhaust on it.
Enjoy
Enjoy
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Sanjay
Aug 12, 2015 03:41 PM
