350 question
Car: 1984 z28 h.o l69
Engine: 355
Transmission: t5
Axle/Gears: 3.73 posi
350 question
I bought a 350 engine block number 10243880 it comes back as a 95-2000 truck engine or a said crate I checked everywhere but there is no serial number to indicate what it was in can anyone shed any light as to what I may have
Posted from Thirdgen.org App for Android
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: 350 question
looks like a vortec roller block. nice score.
http://outintheshop.com/faq/casting/castings2.html
Engine: 355
Transmission: t5
But on the front passenger side pad there is no serial number or sequence numbers so it has to be aftermarket right?
Engine: 355
Transmission: t5
The pistons are flattop 4 valve relief and they have like a bubble cross design in the center
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: 350 question
If it has the standard size pistons in it theres a good chance its probly just a regular gm roller block. Doesnt always happen that way but theres a pretty good chance thats what it is.
Re: 350 question
Probably has been "rebuilt", and the numbers were decked off of it.
Doesn't too much matter what ENGINE used to be built out of that BLOCK; whatever it is now, is what it is. Whatever is used to be part of, is GONE forever.
It's a late-model block, has the roller casting stuff in it; who knows what whoever "rebuilt" it put back in it though.
If you want to know what it IS NOW, gotta look at the parts. Flat-tops w 4 valve reliefs is a good start. Measure the bore and see how far it was bored; measure the deck height and see how far "down in the hole" the pistons are at RDC; identify the crank and the rods; identify the cam that's in it (if any); see if the roller appartus is actually present; go from there. Whatever "numbers" the block might have had on it, won't tell you A DAMN THING about what any of that stuff is.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 350 question
I agree. Unless you bought a new crate motor from a catalog or from someone you trust you don't really know whats are in it. What it started as isn't much good right now.
Block id is good for looking at stuff in the Junkyard or getting an idea if a block might work for you combo. It's not going to tell you if someone put a bore on it, swapped parts, sized the bearings because one spun at some point, decked the block, or etc.
If you really want to know what is in it you need to dig deeper and measure things.
Engine: 355
Transmission: t5
Took it to my machinist it's never been bored out still standard bore and he said it's a forged crank so IM doing pretty good so far for 100 bucks IM working on a budget so every little bit helps
NinjaNife
Aug 23, 2015 11:49 AM
