HEI CC Distributor VS Non computer controlled..
Old Jan 16, 2013 | 10:15 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So one my car right now I have to what I believe is a computer controlled distributor but..the 4 prong wire that comes out of the back has never been connected since I bought the car. I was wondering if I could possibly get one of those $100 distributor of summit..and will it work?if so, where would I attach the vacuum advance too?thanks!v
Old Jan 16, 2013 | 10:24 AM
calgutie's Avatar
Car: 1984 Z28
Re: HEI CC Distributor VS Non computer controlled..
and one more thing..how bad is it if I forgot to put the o-ring on the distributor...could this be causing my car not to run right?
Old Jan 16, 2013 | 11:33 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you have asked this question before , buy a non ccc hei with vacuum advance and hook it to a ported vacuum signal on the carb.
https://www.thirdgen.org/forums/tech...-do-i-get.html
Old Jan 16, 2013 | 11:51 AM
calgutie's Avatar
Car: 1984 Z28
yeah my bad..dont mean to be repetitive..
Old Jan 16, 2013 | 02:41 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Aren't you still running the cc quadra jet?
Old Jan 16, 2013 | 03:02 PM
calgutie's Avatar
Car: 1984 Z28
Yes I am
Old Jan 16, 2013 | 05:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by calgutie
a computer controlled distributor but.. has never been connected since I bought the car. !v
Why don't you hook it up seeing you apparently still have a computer controlling your carb ?
Old Jan 16, 2013 | 05:24 PM
calgutie's Avatar
Car: 1984 Z28
Well thats a funny question kus ive been looking for the female side as I cannot find it at all anywhere on the wiring harness...
Old Jan 16, 2013 | 06:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The factory had it coming out of the harness that runs along the firewall, behind the engine. It can be hard to see.
Without it hooked up, you're in constant "limp home mode". Changing to a non-CC distributor won't change that. And, being in California, your only choice is a CC system.
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
